Sponsored by: Real Truck
Manual hubs
Old Feb 13, 2010 | 11:50 AM
03SUPERDUTY250's Avatar
03SUPERDUTY250
Manual hubs
Is it bad to drive around with the hubs in the lock position if yournottingham in 4 wheel drive mode?
Thanks
chris
Old Feb 13, 2010 | 03:34 PM
dqdave1's Avatar
dqdave1
depends on what you consider "bad" is. Lowers mileage, adds wear to components. But it is not "bad" to run with manual hubs locked in.
Old Feb 13, 2010 | 04:19 PM
wrecked77's Avatar
wrecked77
thanks for the reply
Old Feb 13, 2010 | 05:23 PM
spinella's Avatar
spinella
i leave mine locked in for most of the winter.
Old Feb 13, 2010 | 07:56 PM
seminaryranger's Avatar
seminaryranger
I leave mine locked in for weeks at a time when I use my 4WD regularly. I can't notice any mileage penalty leaving them locked. In fact locking the front hubs from time to time could even give benefits such as keeping the u-joints from freezing up due to lack of use.
I'd pump a few shots of grease in the front u-joints and leave them locked in if you live where it snows.
Old Feb 14, 2010 | 09:55 AM
wrecked77's Avatar
wrecked77
yeh i leave mine in when theres snow on the ground, just cause i never know when i would need four wheel drive on the roads or pullin into a parkin lot.. thanks guys for the replies..
chris
Old Feb 14, 2010 | 11:37 AM
FireMe's Avatar
FireMe
On my fire department we have two F550 light rescues, a 2005 and a 2006. Upon delivery of each, the front hubs were locked and other than for a couple of long freeway trips for service, the front hubs have not been unlocked in either truck for over 15,000 miles.
As a Ford tech, I have replaced far more front end components due to corrosion from lack of use than I have ever replaced for being "worn out."
Jay
Old Feb 14, 2010 | 03:23 PM
bterry's Avatar
bterry
There's been theories of better outer axle stub alingment with the hubs locked and even less wear on some parts. I personally believe the posts above have been right on, and it's just fine to leave them locked for a bit.
