Hi Guys: Now that we have an auto tranny we need a rad with a cooler tank in bottom. My question is what is the latest radiator made that will fit this 1964 f100 truck maybe as new as a 70's. Thanks for any info. Joe
You do not need a radiator with a trans cooler inside it.
Install an external transmission cooler instead, which is waaaay more efficent, and...
You'll never...ever have to worry about the cooler rusting out, allowing ATF to flow into your radiator.
Joe,
I have an f350 heavy duty radiator that I believe has the ports for an auto trans cooler if you choose to swap out the radiator on your truck. It was a good rad removed from a running driving truck I parted out.
Adam
Thanks for the offer Adam but I live near Niagara Falls, Ontario and I am afraid the freight would out of this world. So I have to find something fairly local. Again thanks Joe
