how to test compression?
Old Feb 13, 2010 | 10:38 AM
300/6 Freak's Avatar
300/6 Freak
how to check compression? I think the rings in my 300 are SHOT lots of blow by from the breather and the dipstick hole.
1. what would cause this?
2. how to tell if I need
A. Rings
B. sleaved cylinders
c. just a new head/valve job
2. Thinking about just buying a remanufactured motor...heck one company offers a 7/70 warranty on long block for 1350.00
Old Feb 13, 2010 | 11:31 AM
ri_truck_guy's Avatar
ri_truck_guy
There are compression testing tools that screw into the spark plug holes that will give you readings for each individual cylinders. Generally, if you're getting enough pressure into the crankcase to blow oil out of the dispstick tube its likely your rings. I onwed a 300 that did just that, and when during a rebuild I pulled the the pistons, the rings literally fell off.
Old Feb 13, 2010 | 11:46 AM
Lazy K's Avatar
Lazy K
What he says.
Remove all spark plugs, fit pressure gauge into first plug hole and spin engine over on the starter until the gauge no longer climbs. Make a note of cylinder number and the pressure reading. Repeat for all cylinders.
You may be able to hire a gauge.
Old Feb 13, 2010 | 02:17 PM
300/6 Freak
well if thats the problem would you guys jsut replace the rings or should I jsut buy a new motor and bolt it up.
Old Feb 13, 2010 | 06:23 PM
83mike's Avatar
83mike
my truck is doing the same thing.....300 l6. Only it's not blowing any out the dipstick tube. or the tailpipe.....
Let me know if you find out for sure what it is.
Old Feb 14, 2010 | 02:04 PM
TA Dave's Avatar
TA Dave
Also make sure you have the carb or throttle body wide open for the test to be accurate.
It's also better to test the motor when its warmed up too.
If you have a low cylinder, squirt some oil in the cylinder and re-test.
Old Feb 14, 2010 | 09:04 PM
Redneck1465's Avatar
Redneck1465
If it is rings, when you put some oil into the cylinder it should bump the compression up a little.
Old Feb 15, 2010 | 07:38 AM
300/6 Freak
yup read that in my haynes manual. you guys rock. still thinking about a new motor though as i just know what i got then.
Old Feb 15, 2010 | 06:48 PM
diggerrigger's Avatar
diggerrigger
Rebuilding the head has put added pressure on the rings. Replaceing the rings at this point would put added pressure on the bearings. And so on.
My 302 is blowing too. I'm saving up for a thorough rebuild.
Old Feb 15, 2010 | 08:39 PM
ozstang65's Avatar
ozstang65
If you just replace rings in worn piston grooves they will work up and down in the larger than optimum gap and break again very quickly. I vote for complete rebuild.
Old Feb 18, 2010 | 11:00 AM
300/6 Freak
oh well I jsut ordered a reman Gopher brand 4.9L long blovk the other day. should be here in about a week :-)
Old Feb 18, 2010 | 09:43 PM
E30tdf's Avatar
E30tdf
Good Call
300/6 Freak
You made a good call going re-man long block (as long as it comes from a reputable builder and with some sort of warranty). Especially if time is a factor for you.
Deciding to rebuild yours really all depends on whether you have connections to a good machine shop and can trust your machinist to do justice. You need to go in with some knowledge about builds and the condition of your engine. Know what to ask for and also know when you are getting skinned unnecessarily (Doing unnecessary work or not getting the work you paid for). Some shops will take advantage, if you know what I mean.
The forum had some real good points about only doing rings also. I bet those thoughts played into your decision.
Tom
Old Feb 19, 2010 | 11:34 AM
300/6 Freak
i never just planed to band-aid my problem and to me just replacing the rings would be just that.
