Running board with lights
Old Feb 12, 2010 | 10:10 PM
Rondall's Avatar
Rondall
I have gotten an after market set of very nice running boards. They are heavy aluminum with lights on top and bottom. They were free and have a universal mounting bracket system. The problem is they are too long for my 05 supercab. What I was wondering was, has anyone ever ran 2' past the cab toward the bed before? I thought about doing this and leaving the last bracket loose with a single bolt to retain the flex. I will cut them down as a last resort but wanted to check others experiences.
My other question is where should you tie the lights in? I was thinking of trying to tie into the door switch so they came on when the door opened. Or is there a better location?
Thanks for any help.
R
Old Feb 13, 2010 | 04:51 AM
Sako 75's Avatar
Sako 75
I have mine tied into the interior auto lighting circut. I am not sure (will check later, after the sun comes up) but I believe the wire you want to tap into is purple/black. You will find under the door threshold trim. It is easy to get to as well - just pierce through on of the rubber grommets - no drilling required.
This circuit will run your lighting anytime the dome lights are on. They will light up and fade out just as the domes do. I found this to work best, as they will come on when you unlock with the remote or kepad.
Old Feb 13, 2010 | 05:08 AM
Rondall's Avatar
Rondall
Thanks, that sounds like what I wanted to know. Snowed 3" last night so I wont me messing with it today
Old May 9, 2010 | 08:15 PM
pooneee's Avatar
pooneee
On a 2004 Supercrew:
Is the wire to tap into for the running board lights black with blue stripe or black with purple stripe? Or something else?
Regards,
Poone.
Trophy_23
Jun 4, 2014 04:04 PM
chefcollins1
May 12, 2014 01:23 AM
SD Dually
Feb 3, 2014 01:05 PM
2006LJ
Nov 20, 2013 10:57 PM
jdw1
May 9, 2012 09:35 AM
