hard starter
Old Jan 19, 2003 | 12:53 AM
Frozen1's Avatar
Frozen1
hard starter
After it's parked for more than 4 hrs, she won't start right up.
I have to give it gas and then it runs for 2 seconds and dies. It always starts and keeps running on the third try though. However, it runs at about twice the RPM's that it should for about 15 mins until it warms up. Then, the RPM's back off to a normal idle. But, when I shut it off, it continues to cough and wheeze for a couple of secs and then finally sighs to a quit. If I start it up immediately after that, I have no problems starting or shutting down. I only have this problem once it sits for about 3-4 hours. I've had this problem for about 3 months. I replaced the fuel pump, but that didn't help. Changed the plugs about 6 months ago. Any ideas as to what might be causing this problem?
Jon
Old Jan 19, 2003 | 01:09 AM
Mil1ion's Avatar
Mil1ion
hard starter
That carb is dried out.
Do you see that little rod coming from the linkage to the front of the carb ,then it has a little arm on it?
Behind that is the key to your success.
When you rebuild a carb that accelerator pump is included.
You can also try and Find just that part.
You might end up having to re-build the carb though,4 years is along time for a carb to sit.
Old Jan 19, 2003 | 11:41 AM
Mike W's Avatar
Mike W
hard starter
Ah Dennis, he said after it sits for 4 hours, not 4 years. Check the choke to be sure it is working ok. I imagine you need it where you are. Run on after shutting down can be caused by too fast an idle speed. Also you might try some premium gas.
Old Jan 19, 2003 | 12:28 PM
Mil1ion's Avatar
Mil1ion
hard starter
Doh !
h <> y .
They're close on the keyboard.
My eyes saw a y.
It was late.
Scoobey doo wasn't there to help!
Thanks
Old Jan 19, 2003 | 06:49 PM
bentkey's Avatar
bentkey
Smile hard starter
I have been having the same problem. I replaced the fuel pump about 3 months ago. When the weather changed to being cool in the mornings the truck was hard to keep running. I put a new supposidly not rebult pump on now I guess in the morning I will know if that was the problem.
Old Jan 20, 2003 | 11:04 PM
Frozen1's Avatar
Frozen1
hard starter
I checked the choke. All appears to be in working order. I sprayed a little carb cleaner to make sure nothing's sticking. Also, I've been putting premium in it for a while now, just because I seem to get better gas mileage that way.
I hadn't thought about it before, but, everytime I fill up, I put a bottle of "Heet" in the tank. Heet is a gasline antifreeze additive. I don't even know if they sell it in the lower 48. A lot of people use it up here to help keep condensation out of the tank. Do you think that might be a problem? Of course, if Bentkey is having the same problem...there goes that idea. I just filled up 2 days ago, so I won't know if the Heet is causing the problem for another week or so.
Another possibility. The rubber gasket on my gas cap is getting kind of dry and cracked. I think I remember someone telling me that you have to have a good seal on the gas cap or it won't draw fuel correctly. But that might just be on fuel injected engines. I'm not sure. Has anybody every heard this before?
Jon
Old Jan 21, 2003 | 12:46 AM
Mike W's Avatar
Mike W
hard starter
I would prefer a leaky gas cap seal at least on early model. The caps used to be vented.
