Sponsored by: Real Truck
HELP
Old Feb 12, 2010 | 04:44 PM
mantonic's Avatar
mantonic
HELP
I've a 99 F-250 S-D w/ 7.3L powerstroke. I started it & I got the usual smoke and rough idle when it first starts cold (aprox. 22 Deg.F here) & went back in the shop. About fifteen mins. later went back out to find that it had stalled, it never stalls. when I tried to start it again, I noticed that the "Wait to Start" prompt would not illuminate. So I began checking the Fuses, and found that #30 fuse in the Passenger fuse panel was blown, I replaced it and tried it again. the "wait to start lite up but only for 3-4 seconds and blew the 30amp mini fuse again. Thinking it may be the glow plug relay I disconnected all the wires connected to it to see if that was the problem. It blew the fuse in 3-4 sec. again. What to do now HELP
Old Feb 14, 2010 | 09:02 PM
RentAMan's Avatar
RentAMan
Talking idle
Do a Cummins swap???
We are all smart butts.
Old Feb 14, 2010 | 10:26 PM
redford's Avatar
redford
FTE Leadership Emeritus
You can get a copy of your owner's manual here:
http://www.motorcraftservice.com/pub.../99f23og4e.pdf
Fuse 30 is PCM Relay Coil, Ignition Coil (Gasoline only), Fuel Heater (Diesel only), Wastegate Solenoid (Diesel only), Injector Driver Module Relay Coil (Diesel only)
Given the temp, I would guess you have a problem with the fuel heater or maybe the injector driver relay coil.
Is your fuel jelled?
