single pipe headers?
Old Feb 12, 2010 | 01:24 AM
DillonZ81ford's Avatar
DillonZ81ford
where can i get ahold of a single pipe header for the 300 six...i have a clifford intake with a Edelbrock 4 barrel and i feel a header will open the engine up nice..any thoughts?......i just put the carb on...my brother tried to put the intake on with his headman daul header but it wouldnt fit.....this is a problem i dont want to run into..does anyone know wich brands fit ....and again im looking for a single pipe haeder because i like the way it sounds right now with a cherry bomb and i dont want to change it...just open it up.
Old Feb 12, 2010 | 02:19 AM
Harte3's Avatar
Harte3
EFI exhaust manifolds are your best bet. With a Y pipe you end up with a single out.
Old Feb 12, 2010 | 10:15 AM
stylin86f150's Avatar
stylin86f150
Yea I am having the same problem I dont want to deal with a y pipe or possibly having to make one. I will porbally just get a efi manifold.
Old Feb 12, 2010 | 01:50 PM
DillonZ81ford
all right ill have to look that up ...does it have the same shape at the head as the stock carberated exhaust manifolds?
Old Feb 12, 2010 | 02:09 PM
85e150's Avatar
85e150
EFI manifolds are two 3-into-1 manifolds, and require a y-pipe to connect to a single pipe. (which is the stock set up ahead of the cats)
They do require some grinding to fit with the stock carb intake, not sure about any other set up.
IMO if you don't have to worry about smog, search out a long-tube header. More effective. More money, of course...
Good luck with it.
