Sponsored by: Auxito
problem starting 97 5.4
Old Feb 11, 2010 | 12:53 PM
flhryder's Avatar
flhryder
I have an F-150, 5.4, 4x4, with 173000000 miles. The problem started the last couple of times I used the truck It would not restart after driving for a short distance and parking. It spins over but it is not firing. It acts like it is not getting gas. I replaced the fuel pump about 200 miles ago. I sprayed starting fluid into the air intake and it fired and almost started. I had it out this morning and shut it off and restarted a couple of times with no problem. I came home and the check engine light came on. I put the code reader on and it read no codes. All systems passed. I have no killed the battery trying to start it.
Does anyone have any ideas to help this stressed out Harley rider?
Old Feb 11, 2010 | 04:02 PM
1975IH200's Avatar
1975IH200
Check the Idle Air Control valve (IAC) mounted on the throttle body.
It may help to clean it with some throttle body cleaner, but it may be better to replace it. It is attached with two small bolts & a gasket.
Old Feb 11, 2010 | 04:08 PM
Joe Finn's Avatar
Joe Finn
A quick test to confirm the IAC as the problem is to depress the gas slightly the next time you have trouble getting her going. If it starts with the gas pedal pressed a little, the IAC is bad.
Old Feb 12, 2010 | 08:06 AM
flhryder's Avatar
flhryder
Thanks, I'll try that the next time. I replaced the battery and it started right up. It was probably the problem. I had read this in another post.
PEG
1997 - 2003 F150
Nov 5, 2014 08:11 PM
Dan Robertson
1983 - 2012 Ranger & B-Series
41
Oct 31, 2014 08:03 AM
5.4Triton
1997 - 2003 F150
15
Mar 30, 2012 07:36 PM
damianbreaux
Jan 4, 2012 08:09 PM
jsmallwood_2000
Apr 4, 2007 09:06 AM
