Which boost gauge should I get?
Old Feb 10, 2010 | 08:41 PM
23larry24's Avatar
23larry24
I am going to buy a set of gauges and I am looking for some input on what boost gauge I should get. Specifically which pressure range should I get? 0-30, 0-40, or 0-60, Thanks for the input!
Old Feb 10, 2010 | 08:45 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Do you plan on doing injectors and a turbo upgrade? If not then 0-30psi will do just fine.
Old Feb 10, 2010 | 08:49 PM
23larry24's Avatar
23larry24
So if I plan on mods I should go with the 40psi gauge?
Old Feb 10, 2010 | 09:19 PM
WideOpenFord's Avatar
WideOpenFord
if your just doing a chip you wont see over 30 psi, if you plan on doing injectors/ turbo get the 0-40 but if not its pointless just makes the gauge harder to read for like a pinpoint reading.
Old Feb 10, 2010 | 11:41 PM
CSIPSD's Avatar
CSIPSD
Isspro 0-40psi... Will work for most mods and gives a good range.
Old Feb 11, 2010 | 12:01 AM
big poppa's Avatar
big poppa
Another vote for the 0-40, I got the 0-30 and wished I didn't but then again I didn't think I would be building either.
