Stalling problem
Old Feb 10, 2010 | 02:30 PM
hawgystyle's Avatar
hawgystyle
Stalling problem
This morning i was driving my truck to school and i was doing about 55mph and for a second all interior electronics just died in the cab and the Rear AntiLock Brake light came on and then shut off. at the same time the truck acted like it wanted to stall out. but instantly everything went back to being ok. On the way home it did it again and then just never happened again. Could some sensor be causing this.
It's a 1988 Ford F-150 5.0L with a new C6 i installed last week. New distributor, spark plugs w/ wires, IAC motor, TPS sensor, starter and solenoid.
Old Feb 10, 2010 | 02:42 PM
lew52's Avatar
lew52
Check all the battary cables & grounds , i had a battary short out on me & it did the same thing , good power then nothing ...Lew
Old Feb 10, 2010 | 02:45 PM
hawgystyle's Avatar
hawgystyle
could a lose neg. on the battery be the problem? it was lose so i just tightened it. im gona check my other grounds soon.
Old Feb 10, 2010 | 02:55 PM
lew52's Avatar
lew52
Yes it could , check everthing & see what it does...
Old Feb 10, 2010 | 02:59 PM
hawgystyle's Avatar
hawgystyle
i just dont know how im gona test it because it happened randomly once in a 15 mile drive
Old Feb 10, 2010 | 03:11 PM
lew52's Avatar
lew52
Yeah thats the hardest think to find , is when you don't have the problem all the time ...
Old Feb 10, 2010 | 03:20 PM
hawgystyle's Avatar
hawgystyle
but im still puzzled on why the anti lock brake light came on when this is happening
Old Feb 10, 2010 | 04:29 PM
lew52's Avatar
lew52
Im not sure what the anti lock brake light would have to do with it ?? It sounds like your having a power problem if everthing stops working , look at the main power wires at the solenoid & starter , would be my guess & battary to ...
Old Feb 10, 2010 | 08:10 PM
hawgystyle's Avatar
hawgystyle
well after taking grounds off and putting them back on it seems to work now. thanks for your help.
