59 Cab and front clip
Old Jan 18, 2003 | 07:30 PM
trouble's Avatar
trouble
Can someone tell me if a 59 cab and front clip will bolt up on a 64 frame??? Thanks John
Old Jan 19, 2003 | 07:37 PM
bhabben's Avatar
bhabben
Lightbulb 59 Cab and front clip
Paul,
Ford went through this phase 53-60 where the front axle was located 4" back compared to before and after. The actual front end parts used between a 59 and a 64 are mostly the same. The steering box is 'flipped' comparing which side of the sector shaft the steering shaft lies. I suspect that if it indeed would bolt on that the front axle would appear to be 4" ahead of the center over the wheel openings. Get out a tape measure and us know what you find out...
Thanks,
Brett
