89 e150 died and will not start
Old Feb 10, 2010 | 10:55 AM
murrhee's Avatar
murrhee
hello,89 e150 5.0 302 auto, i put in a new tps, evp, iac, map sensor, it ran good for a day, stated it today to take kids to school and it started, ran bad then died, would not start back up, i pulled the neg. on batt. let sit, still no start. run codes and got 21, 23, 24, 15. has anyone had this prollem and any way i can get it to at start to move out of way. thanks for any help.
Old Feb 10, 2010 | 03:33 PM
murrhee's Avatar
murrhee
89 no start
hello, i hooked up some jumper cables and took the coil wire from the dist. and left it loose on top of the dist. to see if i could here any popping spark sound, and it fired up and ran, put the coil wire on tight and would not run, then left it loose and it fired up and ran, there must be an answer for this one, moved it out of middle of drive way and parded it. went out in an hour and it fires right up but has high idle after warming up, i have also put in a ect., i will try a ecc next.
Old Feb 11, 2010 | 07:12 AM
Grems4ever's Avatar
Grems4ever
Sounds like you might have a short in the coil connection. It might be worth checking out...
Old Feb 11, 2010 | 08:24 AM
murrhee's Avatar
murrhee
89 no start
thanks Grem4ever, i will look at that.
