Will 5.0 serpentine pulleys fit my '73 400? I ordered Mr. Gasket #4759 for 45 bucks on ebay and wondered if im gonna run in to any problems with these pulleys. Im only gonna run Crank/Water Pump/3g Alt.
They will bolt on to every thing except the power steering pump and that might work too but I don't know if a serpentine belt will work with a V belt style tensioner.
-John
-John
Thanks John im not gonna run power steering the 400 is sitting in a '65 F100 and I dont mind the workout. Gives some a reason not to drive my truck lol. Also im gonna use the alternator as the tensioner since this has worked well for me in the past on a carbed '89 stang.
I finally installed pulley kit Mr Gasket #4759
Crank Pulley fit like a glove
Alternator pulley fit on 3g
Water Pump pulley did not fit I ended up drilling new holes so now it fits.
Everything is aligned properly.
