High pitched squeel
Old Feb 17, 2010 | 08:51 AM
4Ranger4's Avatar
4Ranger4
Originally Posted by dos0711
Here ya go...
Method one...
Replacing the Cam Sync
Method two...
Replacing the Cam Sync part 2
If you have ever replaced a distributor, the method is very similar.
One last word of advice...don't use any other part but a OEM Motorcraft...the others have had early failure rates. O'Reillys is where I got mine...it was cheaper than the "stealership".
Your the man! Thanks!!
Old Feb 17, 2010 | 01:09 PM
dos0711's Avatar
dos0711
Here's the one I used...
MOTORCRAFT Part # DA2094 {Position Sensor not Included #F58Z12A362BA}
Category: Camshaft Position Sensor
Since my sensor wasn't bad I just replaced the syncro...
Old Feb 22, 2010 | 10:34 PM
4Ranger4's Avatar
4Ranger4
I can't find the tool anywhere for a '99 3.0, so ill just have to do it the other way..
Old Feb 23, 2010 | 03:54 AM
dos0711's Avatar
dos0711
I didn't use the tool either. I just made note of where the center rotor was pointing in relationship to the outer housing and dropped it in...took a couple of tries but it worked.
Old Feb 27, 2010 | 04:36 PM
4Ranger4's Avatar
4Ranger4
Alright. I did the swap today, and it only took like 10 minutes!
I did it the same way as dos. It runs fine now, but how would you know if it was off a little bit? Check engine light, or would it even run? How would you know?
Old Feb 27, 2010 | 05:27 PM
dos0711's Avatar
dos0711
I'll confess...I don't know. My runs the same and no check engine light so all is good! I think the computer will compensate for small problems.
Old Feb 27, 2010 | 08:13 PM
Greenbike's Avatar
Greenbike
I replaced my cam syncro today and did it like a distributor replacement and engine ran fine when I was finished. However, I now have a 'hard shift' with the automatic every time that wasn't there before. I checked all vac. hoses to see if any were off or any wiring wasn't plugged in or not completely plugged in. Everything looks like it is supposed to - any suggestions??
Old Feb 28, 2010 | 08:41 AM
dos0711's Avatar
dos0711
If you disconnected your battery, it will take the computer some time to relearn things...
Old Feb 28, 2010 | 08:45 PM
Greenbike's Avatar
Greenbike
Well here is an update from today. I decided to take another look at everything while I was more alert / fresh at the start of the day. I double checked all connections and hose routing / connections - I don't know if it had anything to do with it, but the electrical connector at the air box end of the intake tube slid a little farther on and 'clicked'. When I started up the truck and drove it the automatic trans. shifted flawlessly.
So, I don't know if the connector partially unplugged was the problem or if the computer had relearned what it needed to overnight - yes, I did unhook the battery to change out the syncronizer.
Anyway, thanks for the suggestion!
Old Mar 1, 2010 | 04:22 AM
dos0711's Avatar
dos0711
Glad it all worked out...another 3.0 saved!
Old Mar 22, 2010 | 03:55 PM
4Ranger4's Avatar
4Ranger4
Ok, so my original problem in this thread is back with a vengence. I assumbed it was the brakes again so I looked, and it is not the brakes for sure. It seems to be coming from the CV joint area... so my question is.. Do the CV joints make this noise? It is 100% coming from this area of the passenger side front tire... I am stumped!
Old Mar 23, 2010 | 04:14 AM
dos0711's Avatar
dos0711
There is a wheel/hub bearing that might be the culprit if it only does it while its rolling...
Old Apr 1, 2010 | 10:48 AM
  #28
Flat4ragtop's Avatar
Flat4ragtop
My noise sounds about like yours. I did a reply on the thread titled "front diff exploded view" or something like that. Just bought this pickup a few days ago and has 87K miles. Changed DS front bearing and didn't help. I am suspecting the bearings in the housing. Oil level was considerably low. I could feel some play when I moved the inner CV on the PS. Going to top off the diff oil when I get off work and see what happens then.
Old Apr 1, 2010 | 04:27 PM
  #29
4Ranger4's Avatar
4Ranger4
Hmm.. Keep me posted.
Old Apr 1, 2010 | 08:33 PM
  #30
Flat4ragtop
Well, after refilling the front diff housing with 90w oil and driving a few miles, I think I found the rattle/squeal problem. The bad bearing on the PS of the diff housing was causing the low pitch rattle at highway speed and was doing the squeaking at low speed. The seal is obviously hosed also. It still made noise for about 10 miles but then suddenly stopped when the oil finally reached it. Making a bit of a mess now. Going to start checking parts houses for the parts. Anyone know a good online place for the bearing/seals?
