6Spd Tranny HP?
Old Feb 9, 2010 | 09:55 PM
fordzilla01's Avatar
fordzilla01
6Spd Tranny HP?
Anyone have any idea what the 6 gear stick trannys are good to? Hp wise?
Old Feb 9, 2010 | 10:03 PM
parkland's Avatar
parkland
I remember reading here that the clutch was slipping on higher power tunes....but I don't remember what the power was....
Old Feb 9, 2010 | 10:33 PM
Hiflyer746's Avatar
Hiflyer746
Worry not john! You won't be breaking that tranny with what you are doing or planning on doing to it. By the way. . . everything all done?
Timmy
Old Feb 9, 2010 | 10:50 PM
fordzilla01
Timmy
Yup, finally... after a weekend of hell... Now I just have a coolant issue that seems to blow coolant all under my hood (on the passenger side) and down the side of the truck, but only when I stand on it on the highway. Not sure why... Ideas? (See my other thread)
New Motor questions - Water Leak - Ford Truck Enthusiasts Forums
(No worries about the clutch, I got a 650hp dual disk Southbend now)
Old Feb 10, 2010 | 12:01 AM
fixnair's Avatar
fixnair
I understand that the corvette, BMW and mercedes use the ZF 6 sp. Don't know what the HP is in these cars but probably a darn sight higer than a 7.3.
Old Feb 10, 2010 | 12:15 AM
Hiflyer746's Avatar
Hiflyer746
Check your heater core hose clamps going to the motor!
Timmy!
Old Feb 10, 2010 | 01:16 AM
fordzilla01
Timmy!
Have already, but might not hurt to replace stock clamps with screw type hose clamps... Just doesn't seem to leak when I am parked and just rev the bag off of it... Seems only under high boost... (Hoping its not a head gasket already, as they are the O-Ring Gaskets... Big $$$)
Old Feb 10, 2010 | 01:18 AM
fordzilla01
I don't think its the exact same tranny is it? Even if it is, none of them are moving a 7500lb object or towing up to another 12k behind them...
Old Feb 10, 2010 | 07:41 AM
03_PSD's Avatar
03_PSD
I've heard some guys on other forums talking about 550 hp on our stock trannies and they are holding up.
Old Feb 10, 2010 | 09:35 AM
megawatt00's Avatar
megawatt00
You may want to take a look at this thread John symptoms seem to be close......
https://www.ford-trucks.com/forums/8...ad-gasket.html
Old Feb 10, 2010 | 10:31 AM
fordzilla01
Arent they usually referring to Autos?
Old Feb 10, 2010 | 10:33 AM
03_PSD's Avatar
03_PSD
Not in this case, they were talking specifically about 6 speeds.
HP junkie
Feb 6, 2013 08:46 PM
pintoches
Jul 14, 2010 09:16 PM
Ford_a_holic
Jun 20, 2003 03:56 PM
f4fran
Oct 5, 2001 01:52 PM
