1978 - 1996 Big Bronco
what can go wrong in an E4OD?
Old Jan 24, 2003 | 01:27 PM
jimandmandy's Avatar
jimandmandy
While the PCM does store engine and trans codes, the OD OFF light on the shift handle blinks for trans problems. The CHECK ENGINE light will only respond to engine faults. A few problems, like the TPS, will cause engine and trans problems. Getting the codes is a must before attempting repairs. IMHO the E4OD is a steaming pile.
Jim
Old Jan 24, 2003 | 01:43 PM
adelyser's Avatar
adelyser
Jim, I have to disagree. My line pressure circuit went out, and it set off the Check Engine light. The O/D light never flashed when this happened. When the circuit was out, it shifted really harsh. I think it depends on what the fault is to set the Check Engine light or the flashing O/D light. If you have a TPS or MAP problem causing the fault, it will indeed set the Check Engine light.
9228.bobcat
Aug 17, 2013 08:43 AM
RavageX
Feb 8, 2013 10:31 PM
Sleder44
1997 - 2003 F150
Oct 5, 2010 11:14 PM
78Ford460
Jun 29, 2006 01:49 AM
LA_BigRed
28
Feb 28, 2005 07:41 PM
