the big swap
Old Feb 9, 2010 | 08:55 PM
jweave's Avatar
jweave
the big swap
can i use a 78 as a donor for disc brakes and power steering on my 66 and exactly what parts will i need?
Old Feb 10, 2010 | 04:43 AM
jowilker's Avatar
jowilker
You can, it is better if you have the same engine and tranny. If you have a 66 352 str. drv., a 78 351M auto is not a good candidate. You will have to swap the steering column at the same time.
John
Old Feb 10, 2010 | 06:55 AM
jweave's Avatar
jweave
thanks for the info
Old Feb 10, 2010 | 05:48 PM
starmilt's Avatar
starmilt
The 78 will work for everything except the power steering pump bracket, and you possibly will need the appropriate pulleys too.
Old Feb 11, 2010 | 04:09 AM
jowilker's Avatar
jowilker
He didn't say, but if he had an I-6 why wouldn't a 78 I-6 pulley set work?
John
Old Feb 11, 2010 | 05:22 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford changed the P/S pump in 1978 on everything except Econoline's.
Not only is the pump different, but so are the brackets and the P/S pressure hose.
The 1978 and later pump is smaller in diameter than the pump used 1965/77, and has a plastic reservoir and dipstick.
The 1965/77 pump has a steel reservoir and dipstick.
Where will anyone find 1978 and later P/S pump brackets that will fit an FE engine?
Old Feb 11, 2010 | 10:17 PM
garbz2's Avatar
garbz2
I have three in stock... Just kidding.....Man i need to lay off the smirnoff....
Garbz
Old Feb 11, 2010 | 11:52 PM
RJP66F100's Avatar
RJP66F100
[quote=NumberDummy;8498678
Where will anyone find 1978 and later P/S pump brackets that will fit an FE engine?[/quote]
If I'm not mistaken, the bolt spacing on the front surface of the pump is the same on both styles of pumps. Also the shaft diameter is the same. So I think the 78 pump, hose and gearbox could be used with the older bracket and pulley.
May be wrong. (we'll see)
