Gear selector/ignition problem
Old Jan 18, 2003 | 06:16 PM
Mr Ed's Avatar
Mr Ed
Turned off my 1991 f150 4X4 auto trans. with gear selector in drive(maybe neutral, cause I was having some sticking throttle problem). Put it to park. Started truck later and turned key to off position and the engine kept running. Turned key to accessory position and engine still kept running. Switched from back fuel tank to empty front tank to shut off engine. Electtricity was still flowing even with key in off position. Removed key lock cylinder from steering column and electric still flowing. Put new key lock cylinder in and problem still persists. I can also now move the gear selector Park thru Drive 2 with the key in the off position. Anybody have any idea what I broke?
