'79 dash Pad
Old Feb 9, 2010 | 05:20 PM
weaver79's Avatar
weaver79
'79 dash Pad
Has anyone removed there's?
I have my dash apart right now, and wondered if anyone has done this, didn't want to put it backand have to take it apart again.
I was trying to chase a vac leak, i couldn't track it. so, replaced insturment panel light.
any help appreciated
Old Feb 9, 2010 | 05:59 PM
montana_highboy's Avatar
montana_highboy
I forget the exact number but there's about 8-10 nuts on the underside of the dash pad that hold it on.
Old Feb 9, 2010 | 06:05 PM
weaver79's Avatar
weaver79
thanks, im going to check it out.
Old Feb 9, 2010 | 08:33 PM
freakboy's Avatar
freakboy
u gotta remove the glove box, radio, and instrument cluster to get to them all. if it wont come up dont pull on it search for more nuts under there.
Old Feb 9, 2010 | 08:50 PM
Customcab's Avatar
Customcab
If your truck is A/C equipped; need to remove or adjust the A/C duct's back way from vents. There 10 nuts; two per section. 1 set at the both ends of the dash pad near door (A post); 1 set between/ center of dash bezel; & one set between radio & glove box door, one set center of glove box door. The ones between bezel & glove box (above radio) has one of the nuts on face of dash, the rest are facing downward from the dash pad. You can get access with the heater/A/c switch panel loose but it has to be loosen and push back as well.
Mitch
Old Feb 10, 2010 | 08:52 PM
weaver79's Avatar
weaver79
awesome, seems simple enough.
I checked it out last night.
Im thinking that when its off, its time to probably repaint the dash and remove and replace the steering wheel and remove the other plstic trim parts for cleaningand paint prep.
