Hi, I just picked up a 79 f250 4x4 that has some extensive rust on it from being a plow truck. I am getting about .19 inches of frame thickness in good areas but is gets as thin a .14 inches. Is this within tolerances? I am also planning on swapping out the bodies with a 79 f150 2 wheel drive I have for parts. How many floor supports are supposed to be on the bottom of the truck cab? Thanks in advance.
I've never looked that closely at the frame and have only held up a machinist's rule once and eyeballed it at .2" to .25" which was close enough for what I was doing at the time.
As for the "floor supports" - do you mean actual ribs under the floor of the cab or the body mounts that the cab sits on that attach to the frame. The latter is 4 (and 2 under the grill/core support) if that is the one you are after.
