slave cylinder
Old Feb 8, 2010 | 02:40 PM
zubrien's Avatar
zubrien
slave cylinder
anyone know any tricks for getting the slave cylinder back on without disconnecting it
oh yeah, its on a 90 f250 ext cab, 4wd 7.3
Old Feb 8, 2010 | 03:07 PM
zubrien's Avatar
zubrien
no tricks?? i am trying to finish getting this truck back together so i can work tomorrow. i was just wondering if there was a way anyone knew of so i dont have to waste all that fluid and time bleeding it out
Old Feb 8, 2010 | 03:46 PM
tecgod13's Avatar
tecgod13
What kind of trouble are you having? You should be able to put it back on by pushing the piston in and sliding it back onto the tranny. If you can't push it back in enough as it is, loosen the bleed screw a crack and you should be able to compress it without loosing much fluid and without having to bleed it.
Old Feb 8, 2010 | 03:57 PM
zubrien's Avatar
zubrien
thanks alot man, i appreciate the info, i cant get it to push in, but i will try cracking the bleeder screw, ill let you know how it goes
Old Feb 8, 2010 | 09:08 PM
Kleenax's Avatar
Kleenax
It took me awhile and a little frustration to figure out how to get the slave cylinder back in too. What I did is to place the pushrod end from the slave into it's spot on the clutch fork, then I pushed HARD to compress the cylinder, and used a small nylon hammer to tap the cylinder body in place so I could put the holding clip in place. It worked like a charm! It just popped into place.
Whiteraisin
Oct 21, 2012 08:07 AM
brosko80
Mar 9, 2006 03:58 PM
myst
Mar 30, 2003 01:34 PM
jowilker
Jun 18, 2002 08:10 PM
