Anyone go from a Minivan to an Expedition and have regrets
Hi Chuck. Can you elaborate on what you did to upgrade. The one Expy I am looking at does have the Class III(sufficient for a pop up) and 4 pin (not sufficient). Did you upgrade the reciever to Class IV, 7 pin plug, radiator, tranny and oil coolers? Is the wiring there for a 7 pin and all you need is the plug and hook it up or do you have to run wires front to rear. Did you use OEM or aftermarket. Any input is appreciated and for $350 I could overlook this as a necessity for the time being. tks
the only difference you are looking at on a 2008+ Expy between the "Heavy Duty" and "Normal" Tow package is the radiator trans cooler. All you need to do is buy and install the "Heavy Duty" trans cooler. it all bolts into place without any modifications required.
a Expy equipped with the heavy duty package is preferred of course, but if you cannot find one, it's pretty easily rectified
Million dollar question. If you only had 2 kids would you still get an EL? I remember back in 2000 when my wife and I were deciding on a Tahoe/Suburban. She thought the Suburban was too big. I said let's drive it anyways. First thing I had her do was pull into a Lowes parking lot(probably a bad decision in retrospect) and try to park it. She about had a panic attack trying to manuver that beast into a spot with cars on each side. Needless to say be bought the Tahoe which she loved.
I would like the EL only for the extra room and longer wheelbase should we ever upgrade to a TT. However, I am scared it will be too big for her just like the Suburban and again a 1 hour test drive will not allow enough time to formalize a size opinion. thanks for your input
Well, the two transmissions are very similar, and still use the same engine. I would assume the 6R80 would fit. But since I have not done it, I do not know. It may come down to how deep your pockets are.
The 6-speed 6R75 is not a bad transmission, but it does seem to have its own little gremlins. I have not had any issues with mine, so far. It has a Mechatronic unit inside the transmission itself. It will learn your driving style and other information over time. Information it collects is saved in the Mechatronic unit in non-volatile memory.
So if the battery is disconnected, the shift data is not completely lost. The 6R75 will simply revert to its last saved data entry.
The tyranny itself is fairly robust, virtually the same as the 4-speed 4R75 it replaced.
On the shifter there is a small circular button with O/D on it. By pushing that button, the 5th and 6th overdrive gears are disabled. The 6R75 is denied access to them.
The 6-speed 6R80 is the new and current transmission used in the Expedition. It is also used in the new 2009-onward Ford F-150 and its many versions including the SVT Raptor.
It has slightly more robust internals and includes tow/haul mode instead of overdrive lock-out. Tow/haul mode alters the transmissions shift logic for uphill/downhill, towing, hauling, etc. Primarily the transmission will hold gears longer before up shifting. This also helps to keep it from hunting.
My old '98 EB Explorer has the good 302 V8 and 4R70W tranny. They're a robust combination that was in Ford's product line for over 30 years. I think the sealed units, whether the chassis, suspension, or the tyranny require regular maintenance, regardless of what they say. Same goes with the lifetime coolant. I think dirt would find its way inside and mess it up.
we're a bit off topic on the tranny subject, but you guys are worrying yourselves into a corner needlessly. I was pushing nearly 500 crank torque (about 400 RWTQ) through my F-150 tranny (older version of the 07+ Tranny) and it held up just fine. I know many guys running almost 550 RWTQ without any issues. Ford has really done a good job making their trannies more reliable. And in the bigger vehicles like the Expy, they have it dialed in pretty good IMO
given the choice again, I would buy a EL even if I only had 1 kid. I went through many smaller SUV's early on in my marriage and we were always low on space with just 1 kid. The EL solves that problem 100%. Especially if you lay down the rear seats...then you have almost a 6x5 area for storage
We went from 02 Chrysler T&C to 08 Expedition Limited 4X4. Love the Expedition in every way (except abysmal gas mileage, but expected worse than the van, but not this bad - avg 12.5) Do miss the extra room behind the 3rd seat, but in front of the 3rd seat is much roomier and more comfortable. Will most likely be keeping the Exp after the lease is up in September as buyout is $20K and it will have about 18K miles on it by then. Would cost too much to upgrade to an EL version as they are running about $36K used and would most likely not have the HD tow package we have now. Not towing anything big right now, but plan to if economy improves.
Bottom line is if room behind 3rd seat is important to you get the EL.
When we trade this Expy it will be just the two of us at home and we'll most likely get a another one and it will be the EL King Ranch / Limited 4x4.
My neighbor has an Odyssey Van and it's been bulletproof. But, you will not regret the getting the Expy.
Tim
Well the wife decided the minivan was not worth giving up for an Expedition as her daily driver. I have to admit the Honda Odyssey is one very nice van and the Touring version just adds to the enjoyment. In addition the sliding doors are just not worth giving up while the children are still 7 and 3 1/2. Just too easy. Drives and handles like a car and a lot of room.
So, added was a 2003 EB, 4x4, with DVD, nav, 2nd row captains chairs, HD tow package, Advance Trac/Stability Control etc. this will be used to tow our popup and to drive in bad weather and take hunting in the fall. Thanks for all the comments and advice. Just another ride in the stable now.
YoGeorge
68
07-17-2016 11:09 PM
airjeff
01-11-2011 07:37 PM
srponies
02-10-2005 05:12 PM
