Tailgate Removal
Old Feb 8, 2010 | 02:14 AM
Roelito78's Avatar
Roelito78
Question Tailgate Removal
Hello Everyone, this question might sound a bit stupid but how do you remove the tailgate on these trucks? I removed the tailgate fall support bars and the tailgate would not come off. Is there a special trick to this? Thanks
Old Feb 8, 2010 | 02:36 AM
brownfoot's Avatar
brownfoot
unbolt the hinge pivots at the bottom of the tailgate, it doesn't just lift off like later models
Old Feb 8, 2010 | 03:04 AM
miottimouse's Avatar
miottimouse
you will have to close the gate to get 1 bottom bolt out [with socket/extension] then open to get the top bolt [while holding it] and lift 1 side at an angle you may want to use some wd40 for a few days before as these bolts can be a real pain if they have not being removed for a lond time
