Best diesel 7.3L or 6.4 or 6.0
#32
The transmissions in the newer trucks are becoming more and more enticing to me. It is becoming obvious that 4-speeds just don't keep up. Will it do the job, yes, but efficiency and power is greatly improved with more gears. I read an article recently that said that Ford and GM are working together to develop 10-speed transmissions for trucks - when that happens, our trucks are going to become even more obsolete.
#33
#34
Yes... Find the quite you want and hit quote. You'll get redirected to the "reply to thread" page with the quote in the forum code ( [QU OTE =blah blah] "here's the quote" [/QU OTE] ). Copy that to your clipboard and go to edit sig and paste it there.
#35
The allison does shift nice though, and can be built tough, but then again even the 4 sp trans can be built tough.
I think stock for stock, ford transmissions are the toughest for the last few years.
#36
#37
#38
While I stand by my 7.3 that I've owned for over 12 years and 376K, I'd look into a 2005 6.0 Excursion if mine for whatever reason got destroyed.
Here's why:
While the 6.0 doesn't have the reputation for reliability that the 7.3 does we've come a LONG way since the fall of 2002. In the 10 plus years since it's release: we now know the issues, the potential issues, as well as how to prevent and remedy them. This is why I wouldn't be afraid to get one as opposed to a 7.3
-The 6.0 was better designed and built to tow, epecially with the 5R110 behind it.
-The air management system allows for more precise and refined power across the RPMs and better fuel economy at times.
-With the 6.0 you get the towing technology that Ford developed without the DPF, DOC, SCR and you're STILL able to work on it yourself if something breaks. The 6.4 and 6.7 trucks don't allow for this, usually when something breaks, it's a trip to the dealer and $$$$$$$$$$$$ if you're out of warranty.
Here's what I would do if I needed to buy one (again if my 7.3 Excursion were totalled, destroyed):
-Blue fuel spring mod, keeps the fuel pressure above 45 PSI keeping the injectors happy
-Updated dummy plugs and stand pipes, prevents a crank, no start condition in the HPO system.
-Updated STC fitting, prevents a crank, no start condition, at the HPOP.
-Atlas 40 FICM, peace of mind knowing that the FICM is in good shape and the motor is making the power it was from the factory.
-Coolant flush with Rotella or CAT ELC then add a coolant filter, again peace of mind as far as the oil cooler and cooling system to prevent other issues.
-MAYBE an EGR delete, but since I'd be deep in the motor, it would be smart to do it.
(The above are assuming I found a truck with good ECT/EOT deltas and no issues.)
It'd be a weekend of work, but when everything was said and done:
-You wouldn't have to wonder or worry if certain maintenance items or preventative maintenance items were done.
-You know things were done right.
-You know you've done your part to make sure you're not sitting on the side of the road waiting for a tow truck.
Aside from the fluids and filters, that's what I'd do then enjoy the hell out of the truck for many miles and years to come.
Here's why:
#39
#40
#41
#42
#44
Thanks, I knew it had to be something easy. I just couldn't figure out what you were talking about. It's been a long week!
