icp reading unsteady
Old Feb 7, 2010 | 02:24 PM
84-250's Avatar
84-250
I just got my terminator scangauge recently. Ive been watching the icp reading and anytime the injectors are on/firing there is a 100psi drop in pressure that happens regularly. If i engine brake, the injectors turn off and the icp varies less then 10psi. This happens hot and cold and i dont have a HPX yet.
Is this cause of the injector 6 and 8 firing after eachother on the same head as the ICP sensor. Do i have a oring leaking?
Just wondering how steady ICP should be.
