95 f250 stalling
Old Feb 7, 2010 | 02:04 PM
jmorgan2622's Avatar
jmorgan2622
95 f250 stalling
I have a 95 f250 351w it will just stall after 5-20min of running then it will start back up after 2 hrs or so. i have replaced the distributor, coil, and ignition mod, still doing the same thing, any ideas what else i need to check.
Old Feb 7, 2010 | 02:23 PM
rla2005's Avatar
rla2005
Does it have spark during the two hour "wait period"? If it does it must be fuel related because last I checked the atmosphere still has plenty of oxygen to support combustion. You have already replaced the most common causes, ICM and distributor/PIP.
Old Feb 7, 2010 | 02:41 PM
jmorgan2622
I have no spark, there is power to the coil and on the tach wire. the tach wire should be flashing during start mode but it has a soild light
Old Feb 7, 2010 | 02:47 PM
rla2005's Avatar
rla2005
Indicates the PIP is not triggering the coil to fire. It wouldn't be the first time someone got a bad replacement distributor.
Old Feb 7, 2010 | 02:51 PM
jmorgan2622
so should i replace the distributor again, how can i test it to see
Old Feb 7, 2010 | 02:58 PM
rla2005's Avatar
rla2005
Two things to try:
1. Pull a plug (ground the outer electrode) or use a spark tester then momentarily ground the negative side of the coil, you should see a spark. This verifies the coil is working properly. If that works go to step 2.
2. Pull the SPOUT, see if you get spark at the tester or pulled plug. If you still do not have spark it has to be the PIP or the circuit between the two. If it does have spark it could be the PCM. With the SPOUT pulled the ICM is left to itself to time when the park happens.
Note: Have you tried checking for any stored codes or ran any KOEO tests? Even with no Check Engine Light (CEL) on you could have a problem and a code to lead you in the right direction.
Old Feb 7, 2010 | 03:18 PM
jmorgan2622
there are no codes
Old Feb 7, 2010 | 04:06 PM
rla2005's Avatar
rla2005
Double post
