transfer case help.
Old Feb 7, 2010 | 12:10 PM
gjwiggins's Avatar
gjwiggins
transfer case help.
Hi guys im new here but have been lurking around for a little while now. I've got two questions for you guys. My truck is a 1979 F150 4x4 http://i69.photobucket.com/albums/i5.../79F150032.jpg. I purchased the truck fairly recently and have been doing a little tinkering with it. After searching this site and countless other forums I thought I had figured out what transfer case I had. However, my shift pattern doesn't match up with a NP203 so I guess it might just be easier to post a pic and get some help. http://i69.photobucket.com/albums/i5.../79F150015.jpg
http://i69.photobucket.com/albums/i5.../79F150016.jpg
Also while trying to figure out the pattern and dealing with this darn B&M shifter I screwed up my linkage or something in the transmission. I removed the B&M and tried to move linkage by hand but nothing. Got under truck and tapped on linkage, nothing. Any help would greatly be apperciated.
Old Feb 7, 2010 | 01:03 PM
c.l.nye's Avatar
c.l.nye
looks like a 203 to me,it may have a part time kit in it. That could account for the shift pattern. as forthe tranny I cant help ya there.
Old Feb 7, 2010 | 01:17 PM
montana_highboy's Avatar
montana_highboy
It's definitely a NP203, the NP205 has an intermediate shaft 3 bolt cover plate on the rear.
Old Feb 7, 2010 | 01:24 PM
gjwiggins's Avatar
gjwiggins
thanks for the replys. However, it seems like the case shift pattern is like an H, with neutral in the middle.
4lo 2lo
-----n------
4hi 2hi
it does have lock out hubs on the truck if that would help. and it does not have a drain plug for the t case only a fill hole.
Old Feb 7, 2010 | 06:09 PM
montana_highboy
It has a part-time conversion kit installed.
Nice truck btw.
