Tongue Weight
Old Feb 7, 2010 | 11:41 AM
mgraveman's Avatar
mgraveman
Tongue Weight
I have an excursion that I just bought.
I am going to take it to California later this year. I have a crate that I need tot ake that is about 48" wide, 54" tall, and 72" deep. It weighs about 800 lbs fully loaded. I was wondering if anyone had an opinion on mounting this on a hitch carrier (I can make one to handle the weight) and carrying this on the back of the SUV.
I have a small utility trailer that could easily carry it but parking when in San Diego will be an issue. Does anyone have an opinion on this? It seems like a lot of weight pretty far back on the thing.
Old Feb 7, 2010 | 01:40 PM
soutthpaw's Avatar
soutthpaw
I would just add firestone air bags and be good to go. if its a diesel then you got about an extra 400lbs on the front axle to offset the weight...
Old Feb 7, 2010 | 03:06 PM
katiesdad7's Avatar
katiesdad7
The rear springs on the Ex re made for comfort not load carrying. My guess is that if you put that much weight hanging off the rear you will be sagging pretty good.
Plus, I don't know if you can extend the length of the Ex by 6'
and not be breaking any laws.
Old Feb 7, 2010 | 04:01 PM
mgraveman's Avatar
mgraveman
I was thinking I'd put it on sideways - so only about 4'.
I am not disagreeing with you - it seems like a lot and pretty far back on the chassis.
Old Feb 7, 2010 | 04:35 PM
Ex03AK's Avatar
Ex03AK
Wrong thread
Old Feb 7, 2010 | 09:25 PM
Forest's Avatar
Forest
The worst thing caused by this is moving the CG (Center of Gravity) of the truck backwards AND increasing the polar moment of inertia (resistance to steering input). Plus, the 2" receiver hitch is "loose". The drawbar will rock around in the tube, exaggerating the rearward CG. Without beefing up the antisway bar on the rear axle, your Excursion may be more difficult to control in a quick maneuver.
Assuming your X weighs 8,000 lb (as mine does), you will be adding at least 10% of this mass about 2' behind the rear bumper, which is already about 4' behind the centerline of the rear axle. 800 lb, 6' behind the axle, is a pretty big shift.
Use a utility trailer. It is much safer.
Old Feb 7, 2010 | 10:11 PM
Rickx's Avatar
Rickx
I think you're crazy for even considering this. Take your trailer.
Old Feb 7, 2010 | 10:24 PM
badutahboy's Avatar
badutahboy
Very well explained.
Old Feb 8, 2010 | 10:11 AM
MagKarl's Avatar
MagKarl
Polar moment of inertia? Please explain.
OP - It's not a good idea. It's not the 800lbs, it's the fact that you want to hang it out on the end of a 4 foot stick. The hitch has to carry the downward 800lbs, but it also has to resist the moment or twist that your 800lbs on a 4 foot long lever is bringing.
Old Feb 8, 2010 | 03:28 PM
howler4x4's Avatar
howler4x4
from Wikipedia (usually a good source for explanations)
For a rectangular section with sides b and h:
In English... An Ex, which doesn't want to turn anyway, with that much weight that far back will be resistant to turning. And also want to keep turning once committed. Meaning it will be a real handful.
Old Feb 8, 2010 | 08:50 PM
Forest's Avatar
Forest
[QUOTE=MagKarl;8484789]Polar moment of inertia? Please explain.
Think about an ice skater. If they are spinning, they can go much faster by pulling their arms into their body. They spin slower by letting their arms out. They are changing the polar moment of inertia (resistance to spinning about a vertical axis). It is conservation of rotational momentum, which is the same as linear momentum, except that polar moment of inertia relates to mass as rotational speed relates to velocity.
Cars and trucks interact with the road through their tires. Ideally, you want to balance the forces on all 4 tires. One of the best handling sports cars on the road is a Porsche Boxster (also Toyota MR2, several Ferraris, long-gone Fiat X19), with the engine in the center of the car (behind the seats) and a very low polar moment of inertia as a result. These cars can change direction very quickly with minimal stress on the tires.
The Excursion (esp. diesels) is reasonably nose heavy, and you can get away with some rear-ward shift. The downside is on original equipment suspensions. It is too soft on the rear axle, combined with the relatively high CG, and very soft anti-roll bars (if you have one at all).
If you move the high CG rearwards on an Excursion, with the already soft roll that these exhibit, it will be worse than trouble. Now you will have a very sluggish response to steering input and the truck will tend to roll around the longitudinal axis. Now, add in the "slop" that 2" receivers have and you have added a "big marble in a box" to slap you around. What load range tires? If they are "D", they will be too soft in side loading. Really bad combination.
Old Feb 8, 2010 | 08:58 PM
Forest's Avatar
Forest
Old Feb 8, 2010 | 11:46 PM
badutahboy's Avatar
badutahboy
The science geek in me REALLY finds this thread interesting...
Old Feb 9, 2010 | 09:56 AM
MagKarl's Avatar
MagKarl
[quote=Forest;8487774]
I agree with your qualitative assessment of how change in CG and mass distribution can affect handling. But, this is not where polar moment of inertia comes into play, what you are describing is called rotational inertia.
Polar moment of inertia is a quantity calculated from the cross sectional dimensions and is used to calculate shear stress or torsional stiffness in a torsion element.
Old Feb 9, 2010 | 06:34 PM
Forest's Avatar
Forest
[QUOTE=MagKarl;8489719]
MarKarl--Oops. You are correct. It's been awhile. I meant to say "mass moment of inertia" (or rotational inertia). Thanks for jarring my brain back into Intermediate Dynamics. My background is primarily thermal/fluids engineering.
pinger
1983 - 2012 Ranger & B-Series
22
Aug 8, 2017 06:15 PM
mxraddad
Aug 10, 2011 04:28 PM
none2
Nov 21, 2010 12:11 PM
2000redford
1997 - 2003 F150
Sep 7, 2007 12:10 AM
Pony Power
All Things Towing
29
Dec 30, 2004 10:33 PM
