check engine light question??
Old Feb 6, 2010 | 10:28 PM
kickerman248's Avatar
kickerman248
ok fellas, i was driving down the road lastnight and my lights were on, then suddnley they shut off and my check engine light came on. and i switched the lights on and off kinda fast and they came back on. then when i stopped and shut her of and started her back up the check engine light was gone. any thoughts???
Old Feb 6, 2010 | 10:39 PM
Bigcat350's Avatar
Bigcat350
Does any one close to you have an AE to check for codes?
Old Feb 6, 2010 | 10:44 PM
zx250's Avatar
zx250
Of the next Riffraff East
Check your main wiring harness connections on the drivers side, under the hood and make sure one of those is not working itself loose. Sounds like you lost DC power for a second.
Old Feb 6, 2010 | 11:11 PM
clintbonnie's Avatar
clintbonnie
Also check the battery connections.. I had a motorcraft battery that the main battery terminal broke right off.. I would remove all of them and clean them.. and re-install..
