Offroad & 4x4
gears
Old Feb 8, 2010 | 12:07 PM
alpha/omega's Avatar
alpha/omega
^^^ Ive got to agree with you there.
In addition...the engine/trans/axles are working much harder to get your 44s TO 60mph with 3.55 gears. You are most likely burning MORE gas by running higher gears than you are saving.
I also highly doubt your truck is getting 19mpg. My 79 F150 300-6 with the stock 1bbl carb, np435, 3.50 gears and 33s got between 18-20mpg on the highway. I rebuilt it with a 4bbl carb/intake and a few other goodies and now I get around 14 or so with the same setup.
Old Feb 8, 2010 | 02:02 PM
Prozon's Avatar
Prozon
Yeah Kirby, those gears seem way to high. I'm sure you'll be a lot happier with some lower gears.
In response to the original post:
5.13ish.. maybe a little lower would be good for you.
Old Feb 8, 2010 | 03:48 PM
82F100SWB's Avatar
82F100SWB
Have to keep in mind that those old Monster Mudders really don't run true to size, and aren't the grippiest of tire, so the amount of hp and gear required to turn them is lessened, but still, 3.55's with 44's of any sort must be painful.
I'd like to have 4.88's with the 38.5's on my truck, will be 5.13's and a doubler with 44's when it does happen...
Old Feb 8, 2010 | 04:19 PM
alpha/omega
must admit I wish I had 4.88s with my first two motors. The third one doesnt seem to have any issues with the 39.5 boggers.
I can damn near bring the truck to a stop on dry pavement at 45mph from a 3rd to 2nd downshift and a blip of the throttle.
Old Feb 9, 2010 | 04:31 AM
Bender99's Avatar
Bender99
4.88 is nice with 38.5's, butt..................... I now have 5.38's on the way!
42's are also in the future.
Old Feb 10, 2010 | 08:10 AM
dillinewton's Avatar
dillinewton
the dana 60s i bought came with 4:10s so i think im just gonna keep those in them for right now, you think i will do fine on that? i just can afford all the quite yet but i plan to run 4:56s
Old Feb 10, 2010 | 08:23 AM
hav24wheel's Avatar
hav24wheel
You will not notice much of a difference between a 4.10 and 4.56s. 4.56 are a bit high for 44s.
Old Feb 10, 2010 | 08:25 AM
dillinewton
so i should stick with 4:10s
Old Feb 10, 2010 | 08:27 AM
hav24wheel's Avatar
hav24wheel
Umm, no, in all reality you should go with at least 5.13s or 5.38s.
Old Feb 10, 2010 | 09:45 AM
alpha/omega
as I was telling Kirby, youll burn more gas getting up to speed (lets just say 60mph) with 4.10 or 4.56s than you'll save once you get there and hold speed a while. 5.13/5.38s would be a great gear for 44s and will actually calculate to a similar gear ratio as factory with factory tires. The weight and rotating resistance of the 44s is going to kill gas mileage regardless of gear ratio. 19mpg with a 300-6 is just rediculous. Id say you'd be lucky if you got anything over 10mpg. I got 12mpg from a rather mild 460/C6 4.56/38.5s and I felt that was extremely good.
Old Feb 10, 2010 | 10:29 AM
Kirbys73F100's Avatar
Kirbys73F100
is just ridiculous
Old Feb 10, 2010 | 11:28 AM
dillinewton
ok well i dont know if the wallet is gonna let me do that yet.
Old Feb 10, 2010 | 02:55 PM
  #28
alpha/omega
Originally Posted by Kirbys73F100
is just ridiculous
ummm why?
Paul, have you checked your gas mileage yet? He has my old motor in his bronco.
Old Feb 10, 2010 | 05:10 PM
  #29
dillinewton
because im poor
Old Feb 10, 2010 | 05:37 PM
  #30
alpha/omega
is just ridiculous
ummm why?
I was talking to Kirby. Whats your name man?
