injector install ?'s
Old Feb 6, 2010 | 05:30 PM
jchosler's Avatar
jchosler
I just got my II's from DIY. time for installation. few ?'s first.
i got the old oil out of the cylinders with my syringe nad cranked the motor by hand 5 or 6 times than wiped out the injector cups as thouroghly as I could. if theres still alittle left in the cylinders, is it bad? how well do the cups need to be cleaned?
Should I use engine grease on just the inj o-rings or the whole injector?
want to make sure I do it write
Old Feb 6, 2010 | 06:39 PM
427 fordman's Avatar
427 fordman
I didn't clean my cups out good at all. As long as you're sure you got it all out with the syringe you should be fine. That's all I did. If you pulled the rears first like they say to most all the oil goes back there anyway.
When I put mine back in I just took an oil can and soaked the o-rings all real good. I squirted oil all over the o-rings while holding the injector over the head so when it ran off the injector it went in the head instead of all over. Like I said, I was generous with the oil. Then I just stuck it in and tapped in easy with a rubber mallet. You can tell when its all the way in as the sound changes.
Old Feb 6, 2010 | 11:48 PM
jchosler's Avatar
jchosler
I got it all out with the syringe and than turned the motor by hand so i think i got it all.
How crucial is it to get every drop out?
Old Feb 7, 2010 | 05:33 AM
WALJON's Avatar
WALJON
You will never get every last drop out but you need to feel as though you got out as much as you can so at this point install your injectors and do not hook up the harness to them, take out your glow plugs then put some shop rags over the heads and turn it over a few times with the starter put the glow plugs back in and that should be good enough.
good luck
Old Feb 7, 2010 | 06:45 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
DON'T TURN THE MOTOR OVER BY HAND if the injectors are out.
You are cranking the HPOP and fuel pump at the same time and most likely dumping more oil and fuel back into the cylinders.
Suck out what you can, make sure the syringe gets way down on the low pistons, put the injectors back in and bolted down, then slowly crank the motor. You can then crank a few times by hand or do short clicks on the starter till you know for sure the motor will spin freely.
Some guys pull the glow pulgs and bolt the vc back down after the injectors are back in, THEN you can turn the motor over.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Feb 7, 2010 | 10:29 AM
jchosler's Avatar
jchosler
well ***** . I did turn the motor by hand with the injectors out. looks like im back to the syringe. and than I'll do the glow plug trick.
By the way, Jim, your the man, I couldn't believe how fast I got the injectors. I appreciate your work.
