Old 11-03-2014, 08:54 PM
How-Tos on this Topic
Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
Print Wikipost
2006 Hard steering
Old 05-18-2014, 09:56 AM
Tsibley's Avatar
Tsibley
Tsibley is offline
Don't get discouraged if this doesn't work right away.
My steering got so tight it became a 2 hander. I had heard that the power steering fluid could get contaminated. So while having an oil change I had them flush it out and put in a high quality synthetic... Nothing! I then found this forum, went out to the truck and saturated the steering shaft joints with WD while turning the wheel left to right... Nothing! Saturated them again and let it sit overnight... Nothing! I then went to the quarter car wash and power washed the joints, saturated them with PB Blaster to penetrate and finally with WD to lubricate... My steering is now brand new!
Old 05-18-2014, 02:46 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
I hope you made sure they filled it with Mercon V trans fluid.
...saturated them with PB Blaster to penetrate and finally with WD to lubricate...
There are much better (my opinion) lubricants you can use instead of WD40.
Stewart
Old 03-22-2015, 02:18 PM
Shatrab's Avatar
Shatrab
Shatrab is offline
Steering tightness
This is a great thread as it has saved me a lot of money by not replacing the power steering (as many will diagnose this as), WD -40 did great job initially, a few months ago. Recently it got tight again, so I loosened the top bolt and slid the collar down so I could feel the resistance in the motion of the top u-joint in this steering linkage (the bottom u-joint has a boot and is protected so I didn't bother that one). It showed resistance in one of the two directions of travel. There are 4 tiny rubber sleeves that protect the bearing yolks from the elements, and after pushing a very small screwdriver into the edge of each rubber sleeve and pulling it up, a temporary gap is created that will allow better lubrication. I used WD-40 initially, then dripped oil into the gap (while working the direction back and forth), wiped area off as well as the rusty residue that worked out of the cups, and used a medical needle to inject grease into this area. After a while (about 20 minutes) of working the cups to loosen movement, both direction paths were very loose. I believe I will not have to do this again now that there is grease protecting the u-joint cups.
Thanks to those that correctly diagnosed this issue in this forum!
Old 10-18-2015, 08:30 AM
Forever Free's Avatar
Forever Free
Forever Free is offline
My 2004 f150 has hard steering. I bought a new shaft but the new one doesn't have a slip joint. Is this going to be a problem.
Old 11-13-2018, 01:40 PM
Jason B Hall's Avatar
Jason B Hall
Jason B Hall is offline
Hard steering fixed
I too had a hard steering on my 2006 Ford F 150 Harley Davidson edition. I simply popped the hood sprayed some WD-40 on both universal joints on the steering column shaft and it's like good as new. 225,000 miles on my truck
warrens250
41
03-05-2017 03:50 AM
AGrayson84
1997-2006 Expedition & Navigator
11-22-2016 12:47 PM
LCR
1999 to 2016 Super Duty
13
10-23-2016 12:09 PM
Happyreefer
22
09-19-2016 07:49 PM
Brandynr
20
02-12-2016 11:48 AM
Quick Reply: 2006 Hard steering
