On Shockwarehouse.com, the F250 and F350 front shocks are the same.
The rear ones are different though.
If I have an F250 with the rear blocks from an F350, which should I buy?
I see the issue with the Bilstein BST Heavy Duty rear shocks... which I assume are what you want as opposed to the Bilstein 5100 shocks. The front shock is the same for the F250 and F350 - Part # F4-BE5-2818-HO. The rear shock for the F250 is Part# F4-BE5-C296-HO for a single rear wheel axle. The rear shocks for the F350 are Part# F4-BE5-2819-HO for the single rear wheel axle and Part# F4-BE5-C296-HO for the dually rear wheel axle. One would think that Part# F4-BE5-C296-HO is for the single rear wheel axle on both the F250 and F350.
Call Shockwarehouse.com tomorrow and get clarification before you place your order. Here is their contact information...
Shock Warehouse Inc.
4700 N. Dixie Highway, Ste. #16
Oakland Park, Florida 33334
The part #s are confusing, but that's what Bilstein recommends. http://www.bilsteinus.com/305bilstei...ationguide.pdf
Someone at Bilstein technical may be able to shed a little more light on why the F250 and F350 single rear wheel models don't share a shock, their number is 1-858-386-5900
I placed an order yesterday at Shockwarehouse for the Bilsteins that were meant for an F-250.
They are back ordered on the C296-HO, so I ended up taking the 2819-HO (intended for use on the F-350).
I called Bilstein and they said they are the same, except the 2819-HO is about 1" longer.
hey, all.....reviving a thread here with hopes of help.
I haven't called in yet to shockwarehouse but wanted to get a set of bilsteins.
My two main questions are:
I see they sell bilsteins but they don't show up as available for my 06 KR F350 SRW 4x4. Just Monroe and rancho
Second question, though my truck is stock, can I use the 5100 series shocks and steering dampener or is a lift required?
Thanks,
i'm going crazy reading all the posts trying to figure this out.
