Center console removal ?
Old Jun 13, 2002 | 08:37 PM
beemer's Avatar
beemer
I am going to install a CD changer in the center console like the factory one. Does anyone know how to remove the center console. I need to run the cable through the console up to the radio. Are there any secret screws or clips I need to know about.
This is my first post on this forum. Thanks in advance.
BEEMER
Old Jun 14, 2002 | 11:33 AM
Drawsoncad420's Avatar
Drawsoncad420
It's takes some time and there are alot of different bolts and screws to remove. Im at work, so i cant go into too much detail now, but if you look back into some of the old posts a few months ago, i think i posted a full description how to take it apart. I had to install neons on my sub boxes, and had to take the center console apart to run a switch just behind the cupholders. One thing i can tell you is your going to need a Phillips Head, A Flat Head, A Torx, and a Hex Wrench, or Socket. Ill try to clarify once i get home.
Hope this helps!!
Old Jun 14, 2002 | 11:35 AM
cfholley's Avatar
cfholley
I put a six disc changer in my 98 a couple years ago. It's pretty easy since there are already places for the wires to run. Let me try to remember.. There is a screw in the bottom of the "junk bin" towards the dash, one at the latch on the console door, and a couple in the bottom of the console (mine has a little rubber mat that I had to pull out. Also, take off the console door with the two screws at the hinge on it. As far as I can remember, it pretty much pulled out after that.. Hope this helps..
CF
Old Jun 16, 2002 | 11:13 PM
beemer's Avatar
beemer
Thanks for the info.
I installed the 6 disc changer yesterday. It was pretty easy. It only took a couple of hours to do the installation. I think there were about 12 screws and 4 bolts all together.
By the way I have the stock premium radio with changer controls. I bought a kenwood changer and the adapter cable. Once the changer is mounted, just plug in the cables. It was very easy.
Thanks again,
Beemer
Old Jun 17, 2002 | 12:35 PM
buzzard's Avatar
buzzard
1ole4d
Mar 1, 2017 08:26 PM
15expedition
2015 + Expedition & Navigator
Aug 3, 2016 03:09 PM
Kamstutz
6.7L Power Stroke Diesel
Mar 21, 2015 10:46 AM
dongeovani11
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jun 29, 2014 11:34 PM
Andrew010
Jan 6, 2012 05:46 AM
