Sponsored by: Real Truck
Vacuum line hookup.
Old Feb 5, 2010 | 04:07 PM
hammer65's Avatar
hammer65
Vacuum line hookup.
I have a vacum line loose under the hood, of my 2003 7.3. It appears to be gray,{ I am partially color blind) and come from over the passeger fender well and is dangling around behind the a/c drier. The only place that I can find that it will fit, is a solid pin on part of the a/c air box, I think. This plugs the vacuum line. Is this where it goes?
Thanks to all who respond. Jim
Old Feb 5, 2010 | 08:33 PM
FireMe's Avatar
FireMe
If you have a shut-off valve in the heater hose, it goes to that. Some vehicles do not have the valve, but have the vacuum harness there anyway. If that's the case, it just goes to the boss on the case so as not to cause a vacuum leak.
Old Feb 5, 2010 | 09:45 PM
_Rick_'s Avatar
_Rick_
If FireMe's info doesn't get you sorted out,,, maybe post a photo or two and I'm sure you'll have it sorted out in no time.
Rick...
Old Feb 6, 2010 | 06:39 AM
hammer65's Avatar
hammer65
Vacuum line
Thanks Guy's: That was the answer I was hoping for. Jim
