Suspension Swap
Old Feb 5, 2010 | 07:46 AM
Reid lariat's Avatar
Reid lariat
Suspension Swap
Is it a do it yourself job to add the Strutmasters coil over shocks if you have the tools and some mechanical ability. I am waiting on an estimate and waiting to see what the extended warranty covers but I am also preparing for the worst that it might be cheaper just to eliminate the air suspension.
Old Feb 5, 2010 | 07:48 AM
Reid lariat
I left out some important info. 2004 with 4 wheel drive.
Old Feb 10, 2010 | 11:27 AM
Moto Mel's Avatar
Moto Mel
It's not a hard job but, the air suspension gives a better ride. I changed my Mark VIII to coils using OEM parts from a T-Bird SC and I had to remove the rear spring mounts from the body/frame of the donor and then weld them into my car. This was before changeover kits were available. The kits are a snap to install. If you make the change you should keep all the old parts in case you ever want to go back. Also, be sure to seal the air lines to keep them clean because if you never change it back the next owner might want to.
Old Feb 11, 2010 | 07:41 PM
dgray69's Avatar
dgray69
i agree, do not compleatly remove the system as it will kill resale, but the coil kits are very easy to change out, with minimum pains, and the conversion kits are relitivly cheap
jayjordon
Oct 30, 2016 06:05 PM
EBEAR
Jul 10, 2016 07:04 PM
Reavely01
Oct 31, 2013 11:35 AM
glsurratt
New Member Introductions
Aug 3, 2006 06:17 AM
Rippleone
Jun 30, 2006 09:43 PM
