Tech Help...
Old Feb 4, 2010 | 01:10 PM
MHammer21's Avatar
MHammer21
Tech Help...
Hi Everyone...
New to the site and need some tech assistance. I have an Oil Leak at the Rear Main (assuming) and am curious if someone can point me to an old thread for some help.
Thanks
Old Feb 4, 2010 | 01:29 PM
Action4478's Avatar
Action4478
Welcome to FTE , most likely the leak is coming from the top & leaking down at the rear (looks like rear main) , you will need to get the engine clean & dry first . Most will say not to use a pressure washer , just simple green or equivalent, & a garden hose
Old Feb 4, 2010 | 01:31 PM
MHammer21's Avatar
MHammer21
What are the usual Smoking Guns?
Old Feb 4, 2010 | 01:36 PM
Action4478's Avatar
Action4478
Turbo ped O rings , high pressure oil lines from the pump to the head , Oil galley plugs in the head( rarely) Might also be a fuel leak ...
Old Feb 4, 2010 | 02:29 PM
RRranch's Avatar
RRranch
If it is a stick shift it's a lot more likely that the clutch cover rubbed through the oil pan. If you have the 5 speed take it off and look at the back of the pan. It will only leak while running but you will see two silver lines where it rubbed through.
Use gray rtv from Ford to patch it and let it dry overnight before running it. Otherwise you have to pull the engine to replace it.
Old Feb 4, 2010 | 02:56 PM
MHammer21's Avatar
MHammer21
Thanks RR, but it is an autommatic...
Old Feb 4, 2010 | 03:19 PM
RRranch's Avatar
RRranch
That sucks for you. It's probably the turbo then. It's the next most common thing. I've never had to do a rear seal on one of these yet unless it was part of an overhaul.
If you can get a strong flashlight then look at the back end of the high pressure oil pump also. Its right in front of the fuel filter. Look at it running and see if the oil is pouring out the back of it.
