need help
Old Feb 3, 2010 | 06:03 PM
lab1133's Avatar
lab1133
need help
Replaced the EGR and oil coolers in 04 F350. Got everything back together and started the truck, Everything sounded good, had a little white smoke that eventually went away.I let it warm up and drove it around the block a few times. When I turned it off I started it right back up and it ran real rough, after letting it sit for about 20 min I tried to start it and it wouldn't start. I did get it started again and it sounds like the 2nd cylinder back on the passenger side is not firing or the injector isnt getting fuel. What would cause this or is it just a bad injector.
Old Feb 3, 2010 | 07:31 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Lets bump this one - with everything being computer controled it will be difficult to tell with your description. If you have a scanner you might have some codes to help everyone.
Old Feb 3, 2010 | 09:16 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
If you disconnected your injector harness...check all the connections to make sure one isn't loose or dis-connected.
