will these wheels fit?
Old Feb 2, 2010 | 05:52 PM
rat49f6's Avatar
rat49f6
will these wheels fit with out sticking out anymore than stock ??
20" KMC Rockstars
Wheel Pros
i cant have them rub the inside but i cant have them stick out wider than stock because the truck is getting lowered drasticlly
also what tire size would i need to be close to stock ??
thx in advance
Old Feb 2, 2010 | 06:25 PM
dn29626's Avatar
dn29626
This info needs to be compared to your stock wheels. Then you will have your answer. I trust you understand this info.
<TABLE id=Table2><TBODY><TR><TD><TABLE id=Table8><TBODY><TR><TD></TD><TD class=blackregular></TD></TR><TR><TD>Size:</TD><TD class=blackregular>8.5"</TD></TR><TR><TD></TD><TD class=blackregular></TD></TR><TR><TD>Backside Spacing (in):</TD><TD class=blackregular>5.14</TD></TR><TR><TD>Offset:</TD><TD class=blackregular>10mm</TD></TR><TR><TD></TD><TD class=blackregular></TD></TR><TR><TD></TD><TD class=blackregular></TD></TR><TR><TD></TD><TD class=blackregular></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
Old Feb 2, 2010 | 06:29 PM
Ford79's Avatar
Ford79
Well, I believe stock wheels are 16 x 7.5" with 4 1/4" backspace, not sure of the offset, but guessing zero.
The Rockstars's are 20 x 8.5 with about 5 1/8" backspace. They also have a +10mm offset. They will be about 7/8" further in than stock.
Something in the -15mm offset would be real close to stock, backspace wise, though they would stick out a little more than stock because they are a wider wheel.
I also noted that they have a weight rating of 2200lbs/each. Seems a little light even for a 2wd truck IMO.
As for tires, a 275/55/20 is real close to stock, not sure if anyone makes a tire that size or not.
Old Feb 2, 2010 | 06:32 PM
rat49f6's Avatar
rat49f6
damn i really cant have them sticking out maybe ill have to deal with the 18's
Hiflyer746's Avatar
Hiflyer746
The question should be. . . why are you lowering your truck!!!!!!?????
Timmy
Old Feb 2, 2010 | 06:38 PM
rat49f6's Avatar
rat49f6
Timmy
im lowering it because you wouldnt and because its my truck not urs
Old Feb 2, 2010 | 06:40 PM
7.3 Rocket's Avatar
7.3 Rocket
Timmy
Cause putting a lift on a 2wd truck makes you look like a complete retard.
Hiflyer746's Avatar
Hiflyer746
Oh I'm just razzin ya anyway. Montgomery Gentry. . . "You do your thing, I'll do mine."
Timmy
Old Feb 2, 2010 | 06:48 PM
rat49f6's Avatar
rat49f6
honestly tim how many full size srw truck have u seen layed out on 20's have a diesel
i just love being diffrent
Old Feb 2, 2010 | 09:03 PM
worm5932's Avatar
worm5932
i wanna see it when its done!!
Old Feb 2, 2010 | 09:08 PM
WA.Ranger's Avatar
WA.Ranger
That will look bad a$$ when your done.
Old Feb 2, 2010 | 09:53 PM
big poppa's Avatar
big poppa
I'm interested to see it too, never seen a lowered diesel, ever..
Old Feb 2, 2010 | 10:10 PM
PlatinumPete's Avatar
PlatinumPete
.....really.....?
Old Feb 2, 2010 | 10:34 PM
rat49f6's Avatar
rat49f6
thanks guys just did my taxes looks like it will have a 3"/5" drop by march
Old Feb 2, 2010 | 10:47 PM
rebelchevy02's Avatar
rebelchevy02
Here is how "offset" works. Not really a usefull number. I think the most use it has it how much it will affect your wheel bearing situation. Tell you were the load will be.
Im pretty sure the factory wheels are 16x7's, and I think the backspacing is 4.25. The center line is at 3.5", and the wheel mounting surface is at 4.25. Subtract the two, and you get a positive offset of .75" or 19.05 mm.
The wheels you are looking at are 20 x 8.5, have the backspacing of 5.14". The center line of 4.25", and the wheel mounting surface is at 5.14" Subtract the two, and you get a positive offset of .89" or 22.606 mm. The same width tire, on that rim, should stick in the wheel well .14" more, or 3.556mm.
