Bought a coolant filter
Old Feb 2, 2010 | 05:44 PM
lakewood's Avatar
lakewood
Should be here on Friday, bought from diesel site, plan on doing a coolant flush. Just seeing if it's recommended or not? Probably is.....
Old Feb 2, 2010 | 05:48 PM
69cj's Avatar
69cj
What year truck, miles and coolant service history. A little info goes a long way.
Old Feb 2, 2010 | 05:50 PM
lakewood's Avatar
lakewood
2005, 93k miles, bought from dealer at 82k 7 months ago, they did the 90k ford recommended service.
Old Feb 2, 2010 | 06:02 PM
69cj's Avatar
69cj
Did that service state that they did a coolant system flush with VC-9? If not I would do it myself using the Ford recommended procedure. Not preaching, just my opinion.
Old Feb 2, 2010 | 06:24 PM
lakewood's Avatar
lakewood
im calling the dealer tomorrow to see exactly what they did, planed on the VC-9
Old Feb 2, 2010 | 06:30 PM
69cj's Avatar
69cj
May not be the best write up but thought it might help.
1. Drain coolant
2. Add 2 cans of VC-9 and top off with distilled water.
3. Drive 20 to 30 miles, preferably at highway speeds.
4. Drain radiator at petcock first, then pull lower hose. Then remove block plug on driver side. Not necesary to do passenger side.
5. Remove t-stat. To do this, remove air cleaner. Then 2 nuts on t-stat housing. Pry press. sensor bracket off of studs. Tight fit but it will move. Remove 2 more nuts and pull t-stat and housing from studs.
6. Remove t-stat and put housing back on. Re-assemble everything and fill with distilled water.
7. Run at 1200 rpm's for 3 to 5 minutes and drain as described in step 4.
8. Repeat 4 to 5 times or untill water coming at is as clear as water going in.
9. Install t-stat using new O ring. I used vaseline to hold the O ring in place.
10. After everything is re-assembled fill with a 50/50 mix of Ford premium gold or Zerex GO-5.
11. Start engine and check for leaks. This is a lot easier and quicker than it sounds. If you don't remove t-stat then you have to run truck between each flush till t-stat fully opens and then let cool down to work on it.
Highly recommend installing coolant filter kit while cooling syatem is empty. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Old Feb 2, 2010 | 06:34 PM
lakewood's Avatar
lakewood
Originally Posted by 69cj
Highly recommend installing coolant filter kit while cooling syatem is empty. fficeffice" /><O></O>
<O></O>
Thats why i wanted to do the flush, have to drain the coolant to do the install, so might as well flush the system.
Old Feb 2, 2010 | 06:54 PM
ehgeeray's Avatar
ehgeeray
1. Drain coolant
<O></O>
Stupid question. Why is it not necessary to pull the passanger side drain plug?
Old Feb 2, 2010 | 07:03 PM
Cowboy65's Avatar
Cowboy65
You don't necessarily have to drain the coolant to install the filter. If you decide not to flush simply drain out some coolant and then add it back when the filter is installed. You will loose very little coolant during the process.
Old Feb 3, 2010 | 12:59 AM
03-6L-X's Avatar
03-6L-X
Here is how to do the coolant change with or without pulling the T-stat and VC-9.
It is a compilation of the bestways.
https://www.ford-trucks.com/forums/9...nge-101-a.html
Old Feb 3, 2010 | 10:17 AM
69cj's Avatar
69cj
For what little you gain it is not worth dropping the starter. Five flushes will get it done.
Old Feb 3, 2010 | 07:04 PM
BigRy's Avatar
BigRy
Migt get it a little sooner, they are just north of us in Holiday. I got mine in two days.
