Sponsored by: Real Truck
ALEXMNM49
Old Feb 2, 2010 | 02:15 PM
alexmnm49's Avatar
alexmnm49
ALEXMNM49
OKAY I HAVE A 99 F250 7.3 ON SATURDAY IT WAS VERY COLD START THE TRUCK WITHOUT WAITING FOR GLOW PLUG LIGHT TO GO OUT START DRIVING ABOUT 3 MILE TRUCK CUT OFF COULD NOT RE START THE TRUCK TOW IT BACK HOME SO FAR NO START IT BLOWN A 30AMP FUSE UNDER THE DASH REPLACE IT WHEN I TURN KEY IT POP THE FUSE AGAIN SO FAR I HAD NOT EVEN CRANK IT SENCE I HAD IT TOW BACK TO THE HOUSE WHEN I CHECK WHEN I UNPLUG THE PLUG BEHINED THE FUEL FILTER HOUSING THE FUSE WILL NOT POP .BUT THE MINUTE I PLUG IT BACK THE FUSE POP CAN SOME BODY HELP PLEASE .AND I'M SCARED TO CRANK IT OVER I DONT WANT TO DO NO DAMAGE TO MY BABY
Old Feb 2, 2010 | 03:09 PM
Angrywasp's Avatar
Angrywasp
1. Welcome
2. Stop yelling (all caps) it comes off as confrontational.
3. Use some punctuation as it make your post more coherent and easier to read.
4. Details. What fuse is it that is blowing because not all of us know what the 30 amp fuse under the dash is for the 7.3? There should be a list in the owners manual or a number on the fuse box cover that someone can ID. Take a multimeter and check the resistance between the wiring you're removing and the truck as it sounds like you have a short directly to ground.
Old Feb 2, 2010 | 11:06 PM
JockD's Avatar
JockD
It sounds like the fuel heater element has shorted out. The reason the truck won't start is that this fuse also controls power to the Powertrain Control Module. There is no spark because of this.
You should be able to run the truck with the fuel heater unplugged and the fuse replaced.
Try posting this on the 7.3L Diesel Forum on this site. There are several experts there who can help you.
Old Feb 3, 2010 | 01:19 AM
redford's Avatar
redford
FTE Leadership Emeritus
Old Feb 3, 2010 | 01:26 AM
redford's Avatar
redford
I will try to translate. My additions are in parenthesis.
(I) START(ed) THE TRUCK WITHOUT WAITING FOR GLOW PLUG LIGHT TO GO OUT
(I) START(ed) DRIVING
(After) ABOUT 3 MILE (the) TRUCK CUT OFF
(I) COULD NOT RE START (the truck)
(I had) THE TRUCK TOW(ed)
IT (is) BACK HOME
SO FAR (it will) NO(t) START
IT (has) BLOWN A 30AMP FUSE UNDER THE DASH
(I) REPLACE(d) IT
WHEN I TURN(ed the) KEY IT POP(ped) THE FUSE AGAIN
SO FAR I HAD NOT EVEN CRANK(ed) IT SENCE(since) I HAD IT TOW(ed) BACK TO THE HOUSE
WHEN I CHECK (??)
BUT THE MINUTE I PLUG IT BACK THE FUSE POP(s)
CAN SOME BODY HELP PLEASE (?).
I DON(')T WANT TO DO NO(any) DAMAGE TO MY BABY (truck)
Old Feb 3, 2010 | 01:29 AM
redford's Avatar
redford
Was it cold enough to jell your fuel? Do you use any winter fuel additives?
