Modular V10 (6.8l)
wont run today
Old Feb 1, 2010 | 02:56 PM
jbrianas's Avatar
jbrianas
wont run today
05 f350 v10 auto
47k miles
started today an ran for 5-10 secs then shut off
it would restart and run for a few seconds then die
now it will fire for a second when i crank it - but nothing
it thru codes p2104
p2106
p2111
p2135
also noticed when i turn the key to the on position, instead of the normal couple secs of fuel pump sound i would hear, now i hear a clicking garbled
sound
any ideas?
thanks
Old Feb 1, 2010 | 09:15 PM
Pinky Demon's Avatar
Pinky Demon
When was the last time you replaced your battery? Modern electronics like to go apechit when they are not at exactly the proper voltage.
Old Feb 1, 2010 | 09:27 PM
Pinky Demon
Double Post.
Old Feb 2, 2010 | 06:31 AM
jbrianas's Avatar
jbrianas
battery 11 months, full charge,
sound seems to be coming from throttle actuator on side
of throttle body, im guessing the whole TB assembly will
need to be replaced
i still got some warranty, so it got towed in last night,
hopefully it will be covered
Old Feb 2, 2010 | 09:56 AM
tkroeger's Avatar
tkroeger
Codes...
P2104-Throttle Actuator Control System - Forced Idle.
P2106-Throttle Actuator Control System - Forced Limited Power.
P2111-Throttle Actuator Control System - Stuck Open.
P2135-Throttle/Pedal Position Sensor/Switch A / B Voltage Correlation.
Looks Like something going on with that fly by wire system
Codes came from AutoEnginuity. Maybe gets you headed in right area?
Tim
Old Feb 2, 2010 | 08:10 PM
jbrianas's Avatar
jbrianas
well got it back- it runs
TSB 05-14-4
• WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR
basically new TPS and reprogram
isnt it odd ,the truck wont even run on a tps failure
warranty covered $235 of the $409 bill
Josh
toddev
Apr 1, 2014 12:09 PM
Slomoe
Jan 24, 2014 01:19 AM
patrick77598
Oct 30, 2013 06:51 AM
sammie0126
Mar 12, 2013 04:12 PM
giles45shop
Jan 22, 2008 09:15 AM
