Code reader
Old Feb 1, 2010 | 01:44 PM
Rajczak's Avatar
Rajczak
Code reader
I am interested in purchasing a problem code reader for my 2005 F150 and 2003 Expedition. Can anyone point me in the right direction with respect to where to buy one, and what would be the best one to buy. Thanks in advance!
Old Feb 1, 2010 | 01:47 PM
powersmoked's Avatar
powersmoked
I think it depends on how much you want to spend. i bought a codekey from costco for $29. it works fine. you can get better ones that show more info other than just the codes.
Old Feb 1, 2010 | 01:52 PM
Rajczak's Avatar
Rajczak
I was thinking $100 - $200 range would still be practical for me to spend, but if I don't need to spend that much, I won't.
What kind of "options" do the more expensive ones have that make them worth the extra $$ ?
Old Feb 1, 2010 | 02:26 PM
powersmoked
I found this site it looks up to date Diagnostic Code Reader Reviews - OBDII Code Scanner - Best Car Diagnostic Tools You would looking for a dignostic code scanner. where as i have just a plane code reader.
Old Feb 1, 2010 | 06:56 PM
Greg B's Avatar
Greg B
I would recommend Innova Equus 3150 or 3160 as it'll read all protocols and ABS codes as well. They are also upgradeable for free via the internet. Cost is $160 - $200 range.
Old Feb 2, 2010 | 05:58 PM
Rajczak's Avatar
Rajczak
I purchased a Innova Equus 3150, and it looks like it will do everything I need and more. Thanks all for your input!
Old Feb 2, 2010 | 06:03 PM
powersmoked
awesome......can i borrow it
Old Feb 2, 2010 | 06:29 PM
Greg B's Avatar
Greg B
Great. What I like about it is it'll also work on GM, Chrysler, and imports as well. And the fact that it's upgradeable.
Old Feb 9, 2010 | 04:30 PM
Rajczak's Avatar
Rajczak
What I am liking about it is that it reads "real time" data, as you drive on a road test, and when the vehicle "faults", you push the save button and it records a period before and after the trigger is pushed.
I eliminated the vacuum leak using this method, and discovered the fault code was caused by water in the plug socket. Changed the plugs and she runs like a top again!!
....and let me know whne you need it "Powersmoked"!
Old Feb 10, 2010 | 12:47 PM
matrix660's Avatar
matrix660
If you don't mind using a laptop, you might want to check this out: OBDLink scan tool/OBD interface - ScanTool.net
I have the previous version (elmscan5 USB) and I'm thrilled with it. I also have the enhanced ford diagnostics software add-on that allows the unit to show the ford specific codes from various modules. Support for the software (Scan XL) comes from a company called Palmer Performance Engineering and they provided top notch support when I needed a license converted for an upgrade to the newest version. When I purchased my unit, I actually found that Amazon had a better price and it was sold through the same company.
bkuuz1
Jan 11, 2010 12:02 AM
KCMAGERS
May 8, 2007 12:36 AM
j4brug
2004 - 2008 F150
May 29, 2006 08:43 PM
Finally
Feb 22, 2005 08:29 PM
silvapain
3.0L V6
Nov 24, 2003 11:18 AM
