Swaps
Old Feb 1, 2010 | 01:37 PM
knash0727's Avatar
knash0727
Swaps
So I found a good donor truck to fix my 85. It is a 86 F250 that I picked up for $400. The body is a pos but it has a good strong motor and a smooth shifting t-19. I blew the head gaskets in my 85 so rather than fixing the heads I figured I would just pull the motor out of the 86 and put it in my 85. I also want to covert my c6 to a t-19. On a scale of 1-10 how hard will this be? Would it just be eaiser to take the body off my 85 and put it on the 86 frame?
Old Feb 1, 2010 | 01:49 PM
starmilt's Avatar
starmilt
Swap the motor and tranny and the pedal assembly. It is an easy weekend project.
Are they both standard cab 2Xs.
Old Feb 1, 2010 | 02:02 PM
knash0727's Avatar
knash0727
Yep. Both are single cab 2xs
Old Feb 1, 2010 | 02:27 PM
starmilt's Avatar
starmilt
Both has the same wheel base so everything will swap over real easy. Both have the same glow plug setup so you can leave the wiring on the motor and just unplug the harness.
Old Feb 1, 2010 | 02:28 PM
knash0727's Avatar
knash0727
Sounds good. Any major problems to look for?
Old Feb 1, 2010 | 02:41 PM
starmilt's Avatar
starmilt
Nope changing the pedal assembly will be about as big a pain. I would pull the tranny first don't try to pull them as a unit.
While you have the pedal assembly out look closely at the stud that connects to the clutch rod and the rod itself as these tend to wear also the plastic bushings in the pedal assembly itself. They are cheap and easier to replace while it is out.
More than likely on the standard cab there has been a reinforcment plate added use this on your cab to keep it from cracking from the force of the clutch.
Old Feb 1, 2010 | 03:00 PM
knash0727's Avatar
knash0727
Sounds good. Thanks for the info star
Old Feb 1, 2010 | 03:04 PM
greywynd's Avatar
greywynd
Take lots of pics for us to enjoy your labour? We can even crack open a cold drink or two while you work. lol!!
Old Feb 1, 2010 | 03:07 PM
knash0727's Avatar
knash0727
LOL... Drink one for me. Coors Light when I can afford it. lol
Old Feb 1, 2010 | 03:37 PM
starmilt's Avatar
starmilt
It has now become mandatory to document all smashed and bloody pinkys also. lol
Old Feb 1, 2010 | 03:38 PM
knash0727's Avatar
knash0727
Aww... Ill send you the er bill star
Old Feb 1, 2010 | 07:42 PM
greywynd's Avatar
greywynd
Forgot to add, some of this stuff can be done ahead of time, swapping in a pedal assembly with a clutch pedal for example, just means the extra pedal is there, but ready for the tranny swap for example.
Old Feb 2, 2010 | 09:30 AM
knash0727's Avatar
knash0727
So even with my 85 being an auto the pedals will just transfer no problems?
Old Feb 2, 2010 | 10:04 AM
81Bronk36's Avatar
81Bronk36
Ya you have all the peices in the donor truck
Old Feb 2, 2010 | 10:56 AM
knash0727's Avatar
knash0727
The truck has all of the parts.
