Can anyone tell me what rear end this is. Its off of a 77 F150. 4x4. 351M. 4 speed. 8ft bed. And think the truck was originally brown. Hahaha. Hope these pics go through.
It does not have a cover on the backside. Its fom a 77 with 5 wheel lugs. The I.D. tag with the numbers on is gone. It has 10 bolts holding the front cover that hold the drive shaft. The numbers 4F26 are on a small tag riveted to the cover. Also theres is a circle with #'s 1 3 5 7 & I think a U inside of it. One more thing. It has a symbol the looks like stretched letter M with 2 C's inside each other below the M and #20 below it. With out the pics its hard to discribe. I'll try em again
it's definitely a 9 inch, but the second picture only shows casting numbers in the axle housing. The is usually a metal tag under one of the bolts that hold the center section in...obviously it could be long gone by now...
