HELP! Cab bushing removal
Old Jan 31, 2010 | 09:03 AM
radtech's Avatar
radtech
I'm trying to remove my cab bushings. They are tight as hell and I can budge them. Is it possible to sawzall them from below between the rubber bushings? I tried to make a "puller" to remove them from underneath. I was bending 3/4" square tubing because they are so tight. Thanks!
Old Jan 31, 2010 | 09:48 AM
pete17c's Avatar
pete17c
I'm not 100% on this, but since I have to do this soon as well, I throw it out there for comments ..
I think you need to take one of the bolts, thread it back in the bushing, and then use the ol' BFH to drive them out from the top .. and of course lots of penetrating oil first ..
Old Jan 31, 2010 | 11:10 AM
pete17c's Avatar
pete17c
been looking around for an answer .. found this that might help .. Ford F350 Cab Bushing Removal pictures from trucks photos on webshots .. the ads on this site are horrendous though ..
Old Jan 31, 2010 | 02:40 PM
goodB0Y's Avatar
goodB0Y
I found a trick that works really well... it's explained in the thread:https://www.ford-trucks.com/forums/8...ent-guide.html
People have cut them, drilled them, and torched them out... all of which are not fun at all. The procedure I used was the easiest by far but might render the old mount and hardware unusable... most of the time it's garbage any how.
Any how good luck!
billyrb
Oct 17, 2015 10:31 AM
ChrisMelton78
Sep 28, 2014 01:07 AM
BossFan
Jun 20, 2014 08:49 AM
miottimouse
May 6, 2012 08:17 PM
LCAM-01XA
18
Mar 17, 2010 10:40 PM
