ABS light
Old Jan 30, 2010 | 02:17 PM
charles09's Avatar
charles09
ABS light
ABS light is on. and when I barely push the brakes my back ones Lock up and slide also my truck will veer to the right side when i hit them. whats wrong here?
Old Jan 30, 2010 | 06:18 PM
greywynd's Avatar
greywynd
Mine's been on for years, it's disconnected at the sensor on the rear axle. If your truck is veering or pulling to the right, I'd say you have a caliper on the front seized up, likely front left, not allowing the left side to apply. This can also force more braking pressure to the other wheels, which may be part of the reason for the rears to want to lock up.
I'm in Ontario, so here it's just normal operating practice to tear the fronts apart and free them up, usually every spring, on all my vehicles.
