in need of good advice...
I recently bought a 2004 f-350 crewcab 6.0 longbed 4x4..I love the truck so far its done everything I wanted it to do and more....but now after seeing these different web sites that are trashing the 6.0 f350 and all the problems these people have had, I wonder If I should have stayed with my old f-150?....I have a 2 year warrenty but it does not make me feel much better after seeing so many unhappy customers.....does anybody have something good to say about these trucks?......
You only read on the net about all the bad trucks, millions out there? with no issues.
I had a 00-7.3 for 60k miles no issues then a 05-6.0L. It had surge problems under a big load going up hills. Ford or the super techs around here could not figure it out. I could live with it and learned how to drive it through the surge. It was a pain.
My wife would not drive it.
I too was concerned about 'all the problems'
I decided to sell it and, move over to the 06-V-10. Less issues plugs and maybe header bolts. Sure not that many V10 major issues to be found. Wife loves the 'new' truck.. no problem driving or pulling with it.
If you have a two year warranty drive it for a year and if you are having problems with it that gives you a full other year to get rid of it. You read about the people who have problems like person above most people biatch when they are unhappy and shut up when things are good. More than likely you got it right when you said buyers remorse spending a big chunk of money comes with its own guilt and hope that you did the right thing.
The only other cure is the V10... which is what i did. I almost bought a 6.0 used... read more about them and bought the gasser instead. No remorse here. Best of luck to you though.
I've been told that you can not let these 6.0's sit long.....you figure it out...I bought mine new in Aug '05. I now have right at 40k miles on it. Yeah, it sits a lot. When I DO drive it, I drive the snot out of it....The only thing it's ever been back to the dealer for is the turbo hose blew off way back when.... and while on a cross country trip with my 5th wheel. Pulled it into a dealer in Dallas/Ft Worth area.... got it back in about and hour and have been driving it like I stole it since...WHEN I drive it. I love this truck!
OP: I have a 6.0 and it has seen the inside of a shop once since I drove it off the lot, and that was for a power steering fluid leak. Don't let the horror stories fool you. There are a few things you can do that will significantly raise reliability. Peruse the 6.0 forums, especially the tech folders, and you'll learn a lot about how to maintain your engine for many years of trouble free operation.
Good luck and enjoy your new ride.
never owned a diesel..
thats good advice I keep checking the web for PM advice....I was told that you do have to drive the hell out of it at the dealership, I dont know if that was they'r way to "say hey you got shafted now this is the only fix"...I did get the two year warranty, it seems to cover all the expensive things...I do love the truck...my old f150 was just having to many problems..plus I needed something that had some pulling power...I really dont need five hundred hp so I'll keep from doing any mods that would risk it spending more time in the shop then on the road...I drive alot and I put a hell of alot of miles on my previous trucks so I wanted something that can take a beatin and still go the distance...I have herd great things about the v10 and of course the 7.3...the dealership keeps reassuring me the 05 and 06s had the most problems...they have tried very hard to be helpful and adress the concerns I have had...
Fret not.
Free advice:
1. Make no mods to motor
2. Cetane booster in every tank
3. Buy fuel from the same place, one that uses lots of it.
4. Don't be afraid of it
5. These motors do not like to be hot.
6. These motors do like to work.
7. Filters at recommended intervals or sooner.
8. Check for Turbo coking now and then.
Free advice:
Lucky for you, you've found FTE. Scroll further down the main forum listing and you'll find the 03 - 07 6.0 diesel section. There's lots of good info down there. Read up on things and ask questions. Soon you'll have a better understanding of your motor and know the weak links. Once you know what to look for, you can either adjust your driving habits, or make certain modifications to ensure your truck gives you a couple of hundred thousand miles of performance.
Knowledge is power, and learning from others experiences is the cheapest way to gain the knowledge. That's where FTE comes in.
I own a 2006 6.0 and I love it. I work for a large fleet that has about 400 pickups and mechanic service trucks. We have both Gas and Diesels, Fords (7.3, 6.0,5.9B, and 6.4's) Chevy/GMC (6.5,6.6) Dodge (5.9B, 6.7B)and we really have very few engine related problems with any of the trucks. We do not put tuners or high performance accessories on any of them. We do change all of the fluid and filters on a very regular schedule and try to use the OEM filters and follow the OEM recommendations on fluids and additives. Our Ford 6.0's have been great engines not much in the way of problems other than routine maintenance. We are in the Nevada desert and they definitely get a work out on a regular basis. Our fleet has 1993 to 2009 and we usually run them 3 to 400,000 miles before we retire them. If you do not drive very much you would be better off with a Gasser because you will spend a lot less on routine maintenance, but this is still America and you should be able to drive what ever you want just because you want to. You definitely won't be going wrong with a Ford.
