front end clunk
Old Jan 29, 2010 | 11:18 PM
rustyclutch's Avatar
rustyclutch
front end clunk
my 96 f150 4*4 has developed a fun new noise on the front end to make sure I spend some more quality time with her. A loud clunk comes from the front end everytime I turn or step on the brakes after the truck has been sitting. It only clunks once, either when you apply the brakes for the first time or turn left, then drives fine and quiet after that. I have replaced all th U joints, ball joints and radial arm bushings within the last two years and am at a loss on this one? any hints or help would be much appreciated. <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
Old Jan 30, 2010 | 12:06 AM
9.ford.5's Avatar
9.ford.5
id pull the wheel and take a close look at your caliper to make sure its not been moving around
check the bearings to make sure theres not play in them...check the ball joints again...that sounds like the problem to me
Old Jan 30, 2010 | 10:25 AM
A1C DiMaggio's Avatar
A1C DiMaggio
mine is doing the exact same thing, let me know what you find out
Old Jan 30, 2010 | 11:00 AM
roadtrash43's Avatar
roadtrash43
check your radius arm brackets mine has a couple of rivets that are stretch out and the bracket is moving around
Old Jan 30, 2010 | 01:16 PM
ri_truck_guy's Avatar
ri_truck_guy
Yeah....I'd be interested in this answer also....
sddesigns
New Jersey Chapter
Apr 14, 2010 01:55 PM
sddesigns
New Jersey Chapter
Mar 24, 2010 11:43 AM
sddesigns
New Jersey Chapter
Mar 15, 2010 02:29 PM
sddesigns
New Jersey Chapter
Jan 28, 2010 05:46 PM
