melted harness
Old Jan 29, 2010 | 07:38 PM
dthezan's Avatar
dthezan
melted harness
new to posting but really need help. I have a 97 f250 w/ 215,000 mods include superchips programmer K&N air,and no cat back.Started running very rough and had no power and was not smoking. The next day still running very rough and started smoking very badly. Smelled like raw fuel. Checked oil level ok and no diesel smell to it.Pulled the valve covers and three of the four plugs had melted pins. They were the outside wires(for the glow plugs?). Would that cause the rough running and smoking? I dont have a way to check the injectors but would like to know if ok while the covers are off. Is there a way to check them on a budget?
Old Jan 29, 2010 | 08:21 PM
chicagodragon's Avatar
chicagodragon
what part of town are you in, iam in metairie?
Old Jan 29, 2010 | 08:44 PM
fordpride's Avatar
fordpride
i'm in baton rouge i think we cam get u going
Old Jan 29, 2010 | 08:49 PM
chicagodragon
more people should post where they are from
Old Jan 29, 2010 | 09:22 PM
dthezan's Avatar
dthezan
I work in metairie, truck is at my work . i live in covington
Old Jan 29, 2010 | 09:24 PM
chicagodragon
no way, i live in metairie and work in covington, off36 by abita
Old Jan 29, 2010 | 09:34 PM
dthezan's Avatar
dthezan
small world. I work at the firehouse by ej high school. I live by lowes off of 190.
Old Jan 29, 2010 | 09:36 PM
chicagodragon
funny. i live by the zypher field. someone here should be able to tell you better than me how to test injectors, i think you need a good scanner.
Old Jan 29, 2010 | 09:40 PM
chicagodragon
did it only run bad in idle? did you try taking the chip out? ive heard mixed stories about super chips
Old Jan 29, 2010 | 09:42 PM
rideracelivemx7's Avatar
rideracelivemx7
a common problem is the harness burning and cutting power to injectors, byt he sounds of it that might be both of our issues! i had 2 and 7 die.
Old Jan 29, 2010 | 09:49 PM
dthezan's Avatar
dthezan
it ran bad all the time. I put the chip back to stock. Had the chip in for years,never any trouble. I hope it is just the harness, but would like to check the injectors while i have it down.
Old Jan 29, 2010 | 09:53 PM
fordpride's Avatar
fordpride
i dont think it's your programer i've had my superchips for 4 years now and no problems. change harness,vavle cover gasket's and glow plugs if they are old. most likely the pins in the vavle cover gasket are burnt and giving you bad connections
Old Jan 29, 2010 | 09:54 PM
fordpride's Avatar
fordpride
you can ohm them
Old Jan 29, 2010 | 09:57 PM
chicagodragon
Originally Posted by fordpride
you can ohm them
tell me more about the chip for sale
Old Jan 29, 2010 | 10:08 PM
fordpride's Avatar
fordpride
https://www.ford-trucks.com/forums/4...trade-ads.html it's post#10
